Help with wire ID
Old Aug 27, 2011 | 06:51 PM
91 Dually's Avatar
91 Dually
Help with wire ID
Take a look at this pic. Tell me if this wire is supposed to be hooked up to anything or not. It comes out of the small harness that goes to the fuel bowl.. (fuel heater, water in fuel light?) I can't seem to find anywhere it would go.... Anyone?
Old Aug 27, 2011 | 07:14 PM
bad12jr's Avatar
bad12jr
It's one of the 2. Just not sure which one right off hand. Check to see if it had voltage at the moment.
Old Aug 27, 2011 | 07:15 PM
BuckHammer's Avatar
BuckHammer
I'm going to subscribe to this one because the PO of my truck clipped at least one wire in that area.
Old Aug 27, 2011 | 07:16 PM
bad12jr's Avatar
bad12jr
Iirc it should be hot all the time if its the fuel heater
Old Aug 27, 2011 | 07:39 PM
Copedawg's Avatar
Copedawg
If it is not a spark plug wire, it must be the water in fuel sensor:
Old Aug 27, 2011 | 08:01 PM
fordpride's Avatar
fordpride
Its for the fuel restriction sensor your is plugged with the small brass plug in the FPR
Old Aug 27, 2011 | 08:04 PM
91 Dually's Avatar
91 Dually
OK, IT's for something that my truck (97) doesn't have. Cause the fuel heater and the water in fuel wires are plugged up......Thanks.
Old Aug 27, 2011 | 08:05 PM
pjwoolw's Avatar
pjwoolw
Its the connector for the fuel restriction sensor. You can see in the pic where the plug is in the port where the sensor would be.
Old Aug 27, 2011 | 08:23 PM
Copedawg's Avatar
Copedawg
What Pete said. It plugs in to what looks like a skinny theaded bolt end, IIRC
Old Aug 28, 2011 | 05:52 PM
Hussler's Avatar
Hussler
Here ya go ...
Darrell Thompson
Sep 5, 2014 01:29 PM
Neal 97 250
May 5, 2008 06:45 PM
keepnthepeace
Dec 20, 2005 07:23 PM
1SG
Sep 25, 2003 09:03 AM
