Sponsored by: Auxito
Programming PATS key with AutoEnginuity
Old May 22, 2012 | 10:21 PM
  #31
Locksmith1's Avatar
Locksmith1
Scott... any luck after our phone conversation ?
Old May 23, 2012 | 11:19 AM
  #32
Farmerscot's Avatar
Farmerscot
Mine doesn't have PATS as an option on the first connection screen. The only way for me to get to it is through "enhanced powertrain" then on board testing then PATS.
Old May 23, 2012 | 11:23 AM
  #33
Locksmith1's Avatar
Locksmith1
It doesn't say " passive anti-theft ". ?? What AE version ??
Old May 23, 2012 | 11:48 AM
  #34
Locksmith1's Avatar
Locksmith1
Bear in mind PATS is not always a separate system by that name.*
Case in point, the PATS is located in the PCM on a 2005 through 2007 Escape, but in the 2008 it is located in the HEC.* So, on these vehicles you would never see PATS as a selection at the bottom of the VEHICLE SELECTION screen, but that doesn’t mean we will not support it.
Old Jun 20, 2012 | 11:42 AM
  #35
Farmerscot's Avatar
Farmerscot
I have tried it on a 2000 Mustang also with no luck. Same problem, I just go through the 10 minute wait time and then nothing. AE has been no help, and they ended up sending me the instructions that you wrote. I guess I'm headed to the Locksmith. PM me your email, I have a pic to send you.
Old Jun 20, 2012 | 12:20 PM
  #36
Locksmith1's Avatar
Locksmith1
Michaelr.Lawrence@yahoo.com.
Is it the jet we discussed ??
Old Jun 20, 2012 | 04:22 PM
  #37
Locksmith1's Avatar
Locksmith1
Thats funny cause I forwarded them the successful instructions.. Then they send them 2 u
Old Aug 22, 2012 | 05:56 PM
  #38
atikovi's Avatar
atikovi
I bought a clone Silca key programmer on Ebay for about $200 2 years ago. Prices on line are around $100 now. Had no problems getting a 2008 F150 key programmed then and today I programmed 2 keys for my 1998 Mustang. Also did keys for a 2003 Honda. Thing has paid for itself now.
Old Aug 22, 2012 | 06:26 PM
  #39
Farmerscot's Avatar
Farmerscot
That's interesting, I'll have to take a look. I do fleet maintenance and although AE has been great for PSD it hasn't lived up to my expectations as far as making replacement keys. I have had discussion with AE as late as this week but still no resolution.
Old Apr 14, 2015 | 08:58 AM
  #40
01 EX PSD's Avatar
01 EX PSD
Finally got my second key programmed with AE. I had been trying to do it through the powerstroke 7.3 setting and clicking on enhanced power train then pats. Apparently, I had to select excursion (gas) then I could select the pats module itself. Everything worked perfectly after that.
Old Apr 14, 2015 | 01:53 PM
  #41
atikovi's Avatar
atikovi
I've a Chinese clone Ford VCM and was able to program a key for a 2010 Lincoln with no problem.
Old Apr 14, 2015 | 08:20 PM
  #42
Farmerscot's Avatar
Farmerscot
I'm glad you finally got it to work, I finally gave up on AE other than pulling some codes on the older PSD. The folks at AE didn't support me so I haven't done any upgrades or anything to support them. I ended up paying a friend that had the Chinese clone software to make spare keys for me.
Old Apr 15, 2015 | 02:33 PM
  #43
01 EX PSD's Avatar
01 EX PSD
That's a shame that they never took care of you. I've had to contact their customer support several times for different reasons and they always provided some kind of insight. I have noticed that they will point you in a direction but not get you to the end result. For instance, they advised me I was trying to program the key wrong by entering enhanced power train on the PSD; they said I had to connect directly to PATS for it to work. I found on my own that I had to connect to excursion gas to find the PATS module. It really is a good program, once the little quirks are figured out; but, when time is money I'd rather not be using time with customer support.
Old Apr 19, 2017 | 07:36 PM
  #44
jmalvanos's Avatar
jmalvanos
Originally Posted by Locksmith1
Just from here I see AE problem with PATS on 04 F150 - 02 F150 - 03 F150 - 01 Excursion
Anyone else ? More Vehicles ? Please add to my list
YES 2003 FORD MUSTANG MACH 1. I EMAILED THEM AND THEY SENT ME SEVERAL DOWNLOADS THAT DID NOT WORK. I TRIED FOR 14 HOURS OVER 10 DAYS. I TRIED EVERY OPTION POSSIBLE. FORM PATS TO HEC TO EVERY 10 MINUTE DELAY POSSIBLE.
Old Apr 19, 2017 | 07:40 PM
  #45
jmalvanos's Avatar
jmalvanos
SAME ISSUES
Originally Posted by dchamberlain
I'm trying to help a friend with a 2002 Ford F-150 program a second PATS key. I have AutoEnginuity with the Ford bundle. I know it's supposed to work but I'm not getting anywhere. I did do a lot of searching on PATS but I didn't really find anything that helped me.
First of all, we bought a key and had it physically cut. It looks just like the key he has. I did find a chart in this forum that indicated that the were different key types, but it didn't even list a 2002 F-150, so I can't even be positive I have the right key.
This is the key I bought.
Ford OEM PATS Transponder Chip Key Blank * IN STOCK * | eBay
I put the new key in the ignition, turned it on and connected with AE. I had it read the VIN number from the truck and it indicated it was a 2002 F-150. I selected Enhanced Powertrain, then went to system tests and found PATS key programming. The first attachment below is the menu I got.
I started with "Enable Customer Spare Programming". It had me wait 10 minutes then gave me the following error you see in the second attachment.
Does anyone have any suggestions as to where I'm going wrong here?
Thanks,
I HAVE SPENT 14 HOURS OVER 10 DAYS. ITS NOT US ITS A/E PROGRAM
