Sponsored by: Real Truck
Wiring short somewhere?
Old Aug 26, 2011 | 11:57 AM
didjareally's Avatar
didjareally
This is on my boss' 2002 F250 with roughly 65k miles on it. The other night he went to leave work, turned on his lights and seen the passenger side headlight flash then get dim, he just assumed the headlight blew and went home. Changed the headlight bulb and it is still really dim.
Also over the last couple days some new problems have started to appear. With the headlights ON, the passenger side turn signal flashes fast as if there is a bulb burnt out even though they are all working. With the headlights ON the windshield washer fluid pump runs. Soon as you turn the headlights on, the passenger side turn signal indicator on the dash lights up. Also even with the headlights off, when you honk the horn the turn signal indicator on the dash lights up. With the key in the off position and the doors closed, if you turn the headlights on, the radio turns on and it stays on until you turn the headlights back off and open the door.
I have checked the headlight wiring for any cuts in the insulation where it could be shorting out but have yet to find anything. Any ideas or other things to look for or check? Thanks in advance
Old Aug 26, 2011 | 12:36 PM
BillyBob69's Avatar
BillyBob69
Sounds like the GEM module could be acting up.
These trucks are notorius for allowing water in from around the windshield. It then drools down the inside of the firewall to the backside of the fuse box under the drivers dash.
Have him pull the fuse box under the dash and the GEM module behind it. It there is moisture....have a glass company remove,clean and reseal the windshield.
If there is moisture and drying doesn't fix it then the GEM module could need to be replaced.
Old Aug 26, 2011 | 02:54 PM
1973Ford2004's Avatar
1973Ford2004
Check the ground wires?
Old Aug 26, 2011 | 08:06 PM
didjareally
yup, after messing with several other things, it ended up being a loose ground wire, thanks again guys
krmoore77
1997 - 2003 F150
Dec 27, 2020 08:24 PM
three.on.the.tree
21
Apr 21, 2016 06:36 PM
1980inline6
Feb 6, 2014 09:47 PM
bbokainen
Mar 30, 2011 08:56 AM
Bleuluv
Bronco II
Dec 23, 2003 07:42 PM
