Comp Cam 268h in 400
solid cam and lifters!
If I remember correctly solid cam and lifters around 200 buck and 60 bucks for the break in. the break in uses all the zinc and extra goodies needed to help the cam out. Its not way out on price range but a little extra. MPG does a good job and then you now have scott for your tech support on building you the best cam for your application. Nice having a cam cutter in your corner.
experience matters.
I know I push the MPGheads guys and I get nothing from it. The only thing I gain is Scott Main (mpgheads) keeps in business (20+yrs) and I keep building my fords with a experienced ford guy. Maybe their are better guys out their but I know these guys are one of the good ones. On another note if you keep up with Enginemaster competitions Mpg heads has been involved from the beginning (10 yrs) and has countless hours of DYNO time I would just dream of. They have placed in the top 5 acouple of times and did it with a ford engine actions speak more than words. ran the built up 400 several times. I don't have this privilege so I have to work and trust scott on his cams he cuts for me. As long as I give him good info and things work out. Good input good output! BS in and BS out. its up to me to get it right.
Beechkid, 260 bucks for cam and lifters already broken in is pretty good. I'd imagine a hyd cam and lifters wouldn't be much more. Again if there are any aussie followers out there who know of any cam grinders in OZ I'd be interested to known but I reckon you'd pay through the nose for it. My cam cost just under 2 hundy with freight from an australian supplier , actually a good deal as they were 250+ everywhere else. That didn't include lifters but I won't go there. If I was in the market for a new custom ground cam and lifters I'd give them a call! Approx 3 hundy with freight as long as that didn't get out of control would be cool. I'm just a long way away if anything went pear shaped. I certainly hope the OP doesn't think we're jacking his thread!
Sorry the joys of replying on the work blackberry! Please read cam gronders in oz who offert a break in service. There are plenty of cam grinders heren just don't know if they do break in service.
Im planning on swapping out the stock cam and timing chain in my 78 f250 and putting in a 268h cam. If anyones put this cam in their truck how big are the performance gains. I know that changing out the retarded timing chain will help. But what type of gains will this specific cam give me. Also comp cams says the idle is noticably rough. Hough rough is it? Thanks
Hello. I bought the 268h cam from comp cams for the 400 I'm building right now. I also bought the timing set, lifters, and valve springs that are recommended for this cam on comp cams website. I did not buy the recommended push rods because they were too short for a 400. They recommended push rods are 8.412" long but I think factory was around 9.5". Since I found that out I went back and looked at the rods that came out of the block and rolled them across a granite counter top to see if they were bent even by the slightest and they all appeared to be in great condition. I'm tempted to try the factory rods, however, the spring rate for comp cams spring is 241, which is more than likely quite a bit more than the factory ones were. That said I'm scared the factory rods will bend from the heavier spring rate that'll I get from the comp cams springs. Also the block has been decked .010 so that also might be important to take into consideration. The heads are factory heads with the factory style rockers, so nonadjustable. Any response would be appreciated
Thank You.
Garry
Thank You.
Garry
You replied on a thread from 2011, hopefully someone will reply or maybe make it it's own thread. I have a XE262H in my 400. The machine shop did the installation on the cam and heads. I haven't run it yet, life has gotten the way and the project has been stalled out for a couple of years. I have long tube headers, C6 w/ shift kit, Edelbrock intake w/ Quickfuel carb. Hopefully it will be a decent running rig.
Thank You.
Garry
Thank You.
Garry
I would be very careful with the spring loads. The springs sold by Comp are probably going to give you far more load than you need. Especially open. I'd try for about 90lbs seat and no more than 250lbs open. Otherwise the cam will have a very short life.
351Cleveland C4
May 13, 2014 09:32 AM
'89F2urd
Oct 26, 2011 06:13 PM
