Bearing Problem
Old Aug 25, 2011 | 03:32 PM
74baja's Avatar
74baja
Bearing Problem
Hello,
I am replacing front main wheel bearing hub assembly because the old one was giving a 'whomp whomp' sound and had a lot of play in and out. However with the new hub tightened up, turning the hub by hand gives a thud in the same position each turn. Also, the brake rotor dust shield was falling apart so I reinstalled the hub without it. The axle shaft is also loose in the axle tube and the axle dust seals are somewhat loose in the knuckle and axle tube.
Is this a problem? What could be the issue?
Thanks
Old Aug 25, 2011 | 08:21 PM
dagren99's Avatar
dagren99
Did you look @ the stub shaft before installing the new hub? If the old hub was severely trashed it may have worn grooves into the shaft which would make the new hub feel rough when turning
Old Aug 25, 2011 | 09:36 PM
74baja's Avatar
74baja
Sorry folks, much ado about nothing. I slapped it all back together and it ran great. Thanks anyway.
carlspeed
Jan 4, 2017 07:55 PM
Shattered
Nov 23, 2015 12:59 AM
SpeedRebel09
Apr 19, 2011 05:36 PM
01PS
Jun 28, 2007 11:05 AM
Bigtruckdriva
Apr 24, 2005 01:51 AM
