hey guess'. got another question bout the 1960 ford 4x4 im looking at. it doesnt have a 5x5.5 bolt pattern like a 1/2 ton I'm used to dealing with. were the half ton's a different bolt pattern for 4x4? I do know it's got the inline 6. It looks like the big inline 6. the 262. just seems bigger than that 223 i had a few yrs ago i had in a 64 f100.
also, I'm already already planning on puling the 292/4spd out of my 64 2wd and dropping in this truck if i get it. will that stub shaft between the trans and transfer case be the same. and yes, it has the 4spd on the floor.
It looks like the big inline 6. the 262. just seems bigger than that 223 i had a few yrs ago i had in a 64 f100. 262: 1961/64.
The bolt circle pattern is the same for 2WD/4WD, but F100 is different than F250. There is no specific 4WD wheel. The same wheels were used with 2WD & 4WD.
1955/66 F100's came with 15" wheels. 16 and 17 inch wheels were optional.
5 lug wheels on a 5.50" bolt circle pattern: 1948/52 F1 / 1953/79 F100 / some 1980/83 F100's // 1975/96 F150 // 1966/96 Bronco // 1969/74 E200 / 1975/2011 E100/150.
1953/66 F250's came with 16" wheels. 17.5 and 19.5 inch wheels were optional.
8 lug wheels on a 6.50" bolt circle pattern: 1948/52 F2 / 1953/97 F250 // 1967/97 F350 // 1969/74 E300 / 1975/2011 E250/350.
1960: Ford changed the design of the 223 cylinder head. The valve cover is retained to the head with 8 bolts (1954/59 223's use two studs/nuts to retain the cover).
The same head design was used on the 262, introduced in 1961.
223/262: The intake/exhaust manifolds are on the left (drivers) side / 240/300: The intake/exhaust manifolds are on the right (passenger) side.
