i need help with a part
I'm trying to put my driveshafts back together, but I'm stuck on the slip yolk. Inside the cap that screws onto the yolk, there is a rubber seal and mine is trash. Anyone know where to find a replacement? I looked on Bronco graveyard but couldn't find it, parts stores don't have a clue. Ideas/suggestions? Thanks
Two piece driveshaft: Does the center slip yoke's U-joint have 4 cups that are the same size (1310), or are 2 cups larger than the other 2 (1310/1330)?
If the latter, I can list the seal part number, because there is only one slip yoke like this for 1965/79 F100/150's.
If not, lotsa luck...cuz the center slip yoke has to be looked up in the coupling shaft (4817) parts lists (not under 4602)...and there quite a few for the OP's application.
They are all the same. Maybe this will help, after cleaning it I found a part number.
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/Truck/b6fa6890.jpg" border="0" alt="Photobucket"></a>
<a href="http://photobucket.com" target="_blank"><img src="http://i12.photobucket.com/albums/a204/KBrian/Truck/cb421ed8.jpg" border="0" alt="Photobucket"></a>
P/N looks like: 2-16-263 That's all I can make out
**After looking that up, I can find all kinds of info on it, but haven't been able to find where to buy it yet.
