Head studs complete! One Question?
Old Aug 24, 2011 | 11:27 PM
snorindad's Avatar
snorindad
Just started my truck tonight after ARP studs, dummy plugs, stand pipes, stc, water pump, rodded radiator, heater core, BPD egr cooler, new oil cooler, cleaned exhaust side of turbo, new batteries, blue spring upgrade, re-ringed injectors, new glow plug harnesses, all new hoses(heater and radiator), I am sure I am missing something. After all of that I have a whistle (or whine) coming from the turbo area. Can't quite pin point it. What do you all think it could be. Thanks in advance.
Old Aug 24, 2011 | 11:37 PM
Firemudder's Avatar
Firemudder
Sounds like a exhaust leak. Check to make sure everything is lined up and tight.
Old Aug 24, 2011 | 11:48 PM
snorindad's Avatar
snorindad
That's what I was thinking. Will have to check it out after work tomorrow. Although the truck seems to run smoother and have more get up and go. Also is there any reason to do a turbo re-learn? I did not disassemble the entire unit.
Old Aug 24, 2011 | 11:53 PM
Firemudder's Avatar
Firemudder
Not really sure what a turbo relearn is. Don't think these turbos have to.
Old Aug 25, 2011 | 05:45 AM
texans's Avatar
texans
I'm pretty sure that only 03-04 my have to due a re-learn. Even on them my it will self learn anyways. Same with the tranny.
Old Aug 25, 2011 | 08:36 AM
snorindad's Avatar
snorindad
Thanks for the replies.
Old Aug 25, 2011 | 08:38 AM
High Binder's Avatar
High Binder
I did the relearn on mine after doing the same cleaning. I don't know if it needed it or not but you might as well as it's not going to hurt anything.
Old Aug 26, 2011 | 10:43 AM
snorindad's Avatar
snorindad
The whistle was coming from the up pine to egr cooler. So problem fixed!
Powerstroke2004.5
Jun 9, 2019 07:08 AM
Stu206
Jul 28, 2011 04:59 AM
pskelton
Jun 15, 2011 10:31 AM
mh5500
Jul 15, 2010 06:18 PM
Casey02L
Jan 22, 2008 03:00 PM
