Replacing differential cover
Old Aug 23, 2011 | 11:05 PM
fordtruck661's Avatar
fordtruck661
Hi guys Im looking at replacing the differential cover because it is rusted bad and looks to be leaking oil from the middle and bottom of the cover. just some of the questions i have are would you use a gasket or Permatex. Also Im thinking of just using 85W-140 oil for it seeing that its around $13 cheaper than the 75W-140. Any tips would be great.
Thanks
Old Aug 23, 2011 | 11:14 PM
snakedoc's Avatar
snakedoc
i would get one from a 08+ there bigger and look good.
http://www.riffraffdiesel.com/catego...DIFF-FORD.html
Old Aug 24, 2011 | 07:05 AM
Ponyboychris's Avatar
Ponyboychris
Here's a good write-up. Welcome to guzzle's Rear Differential Maintenance Web Page
There's no gasket, just use some good permatex and I let it skin up for 20 minutes before putting the cover on then let it sit for 2 hours before adding fluid. No leaks. It's highly recommended to use synthetic oil (75w-140) and it was the most expensive part of the procedure but given the abuse the gear oil takes in the rear-end, I looked at it as necessary expense.
If you can swing it, get the '08 cover as well from Clay like Matt suggested. They are nice.
Old Aug 24, 2011 | 09:56 AM
rufushusky's Avatar
rufushusky
Thanks
Black RTV works very well, I highly recommend the 08 diff cover, I got it for like $60 bucks at a local ford medium duty shop, then 12 5/16-18x1.25 bolts and your good.
Also ford spec'd a 75w-140 synthetic for a reason, I would use it. Also check to see if you have a limited slip diff..if that is the case you may need to add friction modifier to the fluid. I didn't need to do that with my Redline gear oil but some other brands you might. Really the diffs can run 100-150k+ on a good fluid...I would just throw a synthetic in there and call it a day. Cheap fluid, expensive parts and long drain intervals are not a good mix. Also were are you looking for gear oil? You can usually find mobil 1 75w-140 for like 18 bucks a quart or Amsoil 75w-140 for 16 a quart.
Old Aug 24, 2011 | 10:05 AM
rufushusky's Avatar
rufushusky
I was just thinking you can usually get valvoline 75w-140 for like 12 bucks a quart at napa. Valvoline makes a pretty solid fluid in my opinion.
Old Aug 24, 2011 | 10:14 AM
fordtruck661
When I looked online they were selling the covers with gaskets and for getting the 08 cover I wish i had the $$ for it but I just bought this truck and am short on cash.
Thanks everyone for the replies!
Old Aug 24, 2011 | 05:03 PM
Ponyboychris
yea, there are gaskets available if you ask for one at a parts counter but it's not needed. A good bead of silicone will do the job.
Old Aug 24, 2011 | 08:58 PM
dagren99's Avatar
dagren99
Stick with the silicone - gaskets leak - don't want to lose the pricey 75W140!
6LPSD
Jun 10, 2010 04:13 PM
smlford
Nov 7, 2009 07:32 PM
Ford79
Mar 17, 2009 05:10 PM
Rus01
Aug 25, 2008 08:59 PM
carpe_diem
Jul 18, 2003 10:48 AM
