oil down front of motor
ive just got this truck couple years ago and really wanting to clean up the front of the motor,, there is alot of oil and gunk down the front of it,, never drips on driveway or garage but its pretty nasty on front in. Do you all think its HPOP gasket? also can i degrease the front end and spray it off???
I was able to clean mine up pretty good with some Simple Green. Warm the engine up (warm, not hot) and then spray it with Simple Green (or any other de-greaser for that matter, but I like Simple Green). Let it soak for 10 minutes or so then hose it off gently with a garden hose (not a pressure washer). Once you get it cleaned up you should be able to locate the leak a lot more readily.
mv1967
04-21-2010 08:16 PM
7.3DieselPower
02-25-2008 12:53 AM
Agemenon
23
07-08-2007 11:25 PM
mcn420
04-19-2006 08:13 PM
