Washing the Engine~ Any Good Method?
Old Apr 19, 2006 | 12:17 PM
mcn420's Avatar
mcn420
Question Washing the Engine~ Any Good Method?
My 2000 F-250 had a oil leak on top of the motor by the oil pump. The guy I bought it from already put a new O-ring in. He was afraid of it not starting after cleaning it, which I understand, but there's oil all over the top of the motor from the leaking oil being blown back. It isn't hurting anything, but doesn't look good when I show people the engine. Is there a good easy method to cleaning the motor that won't drown out my electrical connections?
Old Apr 19, 2006 | 12:37 PM
ryaneverk2's Avatar
ryaneverk2
Wrap the alternator and air intake and any exposed electrical connectors with some saran wrap or some sort of plastic covering. Then spray the whole thing down with Simple Green, and let it sit for 10-15 minutes. Then spray it all down with a garden hose.
Old Apr 19, 2006 | 02:28 PM
Hotwheelbill's Avatar
Hotwheelbill
Thats the way I do mine and it looks great. Simple Green is the stuff!!!
Old Apr 19, 2006 | 03:10 PM
mcn420's Avatar
mcn420
Cool, so there's no problems drowning the motor? I flushed the coolant on my Expedition and some water got on the intake and must've gone into a sparkplug hole. It missed and ran terribly when got on it for like 3 days.
Old Apr 19, 2006 | 06:05 PM
ryaneverk2's Avatar
ryaneverk2
The only real trouble spots are the alternator (electrical), exposed electrical connections, and intake - no where else for the water to get in, really. It gets all wet when you're driving in the rain, too. Plus, it's not like you're dunking it in a huge tub... just spraying it for a few minutes. Seems most folks who've done it this way haven't had a problem. I'll probably do mine sometime this summer...
Old Apr 19, 2006 | 06:55 PM
guzzle92's Avatar
guzzle92
All good suggestions and simple green with a garden hose has been the general concensis for some time now. The only thing I could add is do it when the engine is slightly warm, not hot. If you can lay your hand on the exhaust manifold without getting burned, it's just right. It seems to help the simple green cut the oil and grease when it's a little warm.
Old Apr 19, 2006 | 08:13 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
there is a hole in the bottom right corner of the block, near the pedestal (to the right) that will drain all the water. it will go down the back of the transmission. while youre at it, get under the truck (watch your eyes) and spray up past the downpipe to get the backside of the engine.
