oil filter cap
Old Aug 23, 2011 | 01:13 PM
keld's Avatar
keld
oil filter cap
Okay guys, I know this may seem ridiculous, but I have a silly question. Is the o ring on the oil filter cap supposed to be visible after you put the cap back on? I guess I never paid attention before when I changed it before. The o ring squeezed out twice on me this last time, and I had my brother helping me. He insisted it needs to be down inside. So he kept tightening it until it went in and the plastic ridge on the cap touched the metal. I was sure it was going to crack, but so far so good. He did the same thing to the fuel filter cap. I need to find out so I can back it back out if I need to, before it breaks. I've not had problems with leaks before, but this time has been a pain in the butt. thanks in advance for any help on this
Old Aug 23, 2011 | 01:16 PM
renfrizo's Avatar
renfrizo
Pretty sure if you can see the O-ring, it's not doing it's job. Plastic to metal is correct. Torque spec for the cap should printed on the top of it.
Old Aug 23, 2011 | 01:20 PM
keld's Avatar
keld
Thanks...I thought the o ring was squeezed between the cap ridge and cylinder that created the seal, guess maybe I was wrong. I just didn't remember having to crank it down so hard the last time I changed it.
Old Aug 23, 2011 | 01:38 PM
Unrealo4's Avatar
Unrealo4
If you are using a aftermarket filter in a oem cap. It would feel like you cranking on it. Are you using a motorcraft filter?
Old Aug 23, 2011 | 02:05 PM
keld's Avatar
keld
Yes it was motorcraft. I bought the truck used a few years ago. I used an aftermarket filter the first time, but this time I bought motorcraft.
Old Aug 23, 2011 | 04:09 PM
dhag911's Avatar
dhag911
is it a ford cap? when i bought mine it had a napa cap on it and it was really hard to turn
Old Aug 23, 2011 | 04:18 PM
npccpartsman's Avatar
npccpartsman
The o-ring should NOT be sticking out. It goes down in the housing just a bit, not right under the lip of the cap. A new o-ring comes with every filter because the old o-ring will swell and not fit correctly.
Old Aug 25, 2011 | 10:29 PM
FKNVA's Avatar
FKNVA
I used NAPA oil filter once. Never again. The NAPA oil filter had a Cap attached to it.
It leaked.
I had saved the OEM cap. Purchased a OEM filter and installed with the OEM cap.
My local Ford Tech. said he had seen several NAPA oil filter caps leak.
Cory Barrow
Apr 8, 2017 12:33 PM
Number21
Mar 18, 2014 10:09 AM
Ian123
Sep 11, 2013 02:16 PM
MoyockPowerstroke
Feb 19, 2009 09:10 PM
carsrob1
6.4L Power Stroke Diesel
Jan 11, 2009 08:46 PM
