Tailgate strength
Old Aug 25, 2011 | 04:02 PM
CornTruckDriver's Avatar
CornTruckDriver
Cool
no tailgate step I have no idea if that would make it weaker or stronger. So far it seems a sheet of plywood is the answer. They use to place bales of hay around racetracks to absorb impact.
Old Aug 25, 2011 | 04:05 PM
Sportscraft's Avatar
Sportscraft
Might be harder to slide then plywood but what about a rubber stall mat? Not sure if it will absorb as much impact but at least it won't weather.
Old Aug 26, 2011 | 05:25 AM
mistakenID's Avatar
mistakenID
I'd attach a 3/16 piece of diamond plate to the whole tailgate, minus the area needed to close the tailgate. Strengthen the whole thing and wouldn't look too bad.
Old Aug 31, 2011 | 06:49 PM
doczenith1's Avatar
doczenith1
So what I'm hearin' here is that this fall when I'm tailgating I should not throw my 200lb friends on to my tailgate...which is sort of common sense because it would make their beers foam up.
schoo
Mar 14, 2012 08:36 PM
tomtoc
Aftermarket Products
May 11, 2007 08:12 AM
jm5770
Paint & Bodywork
Feb 4, 2006 11:08 PM
drade
Sep 6, 2002 10:47 AM
Andy63
May 10, 2002 12:41 PM
