Voltage Meter Problems..?
Old Aug 23, 2011 | 07:02 AM
Rockaholic's Avatar
Rockaholic
Anyone had any known issues with the voltage meter? And would u recommend i get a new alt as well or just grab the voltage meter?
Old Aug 23, 2011 | 09:15 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Kinda scetchy on info. What problem are you having? What vehicle etc.? Wouldn't spend any money till you isolate the problem. If unable to test yourself, stop by Advance/Autozone and have charging system checked, it's free.
Old Aug 25, 2011 | 07:54 AM
Rockaholic's Avatar
Rockaholic
sorry took me awhile. College just started back up. Its a 1995 f150 XLT 4.9L 2WD with roughly 118k miles on it. I had it tested by autozone and they told me that was the error but i only occurs under certain conditions. Hence it normally happens at night when i have my A/C on, Lights turned on, and my radio going. Never had this problem in the past but it is getting worse as time progresses.
Was going o take it to Advance Autoparts next and discount and see if i get the same readings just incase but i wanted some feedback on here first
Old Aug 25, 2011 | 09:19 AM
88rustyred's Avatar
88rustyred
did they test it with the lights and ac on, to simulate the conmditions when it was actiug up? mine makes a sqweaky noise at 12 volts for about five minuits and quietens out when it reaches 12.5 to 13 volts. there is an external voltage regulator on back of the alternator, maybe that needs replacing. there is a backyard test that i've heard of. hold a screwdriver behind alt,while engine is running, if it feels magnetized then alt is working
Old Aug 25, 2011 | 12:04 PM
rustywheel68's Avatar
rustywheel68
i think you're talking about the voltage regulator.
i'm looking at the autozone website, and a new alternator is going to be expensive.
the new regulator is nothing to sneeze at, either.
is there a junkyard nearby? i can pick up voltage regulators for $5 at the local yard.
Krueger1
Apr 4, 2019 10:16 PM
Locorotc
Oct 11, 2012 07:43 PM
78 Ranger
Electrical Systems/Wiring
Feb 18, 2008 06:21 PM
theswen
Apr 29, 2006 05:02 PM
GeneStoner
Dec 22, 2003 08:36 PM
