Waving voltage meter and lights
Old Apr 28, 2006 | 02:30 PM
theswen's Avatar
theswen
Hi everyone! I own a 1966 f-250, and have a common problem with old cars also. When I 1st start up the truck the volt meter sways fast back and forth, then when it warms up stays steady...but, as soon as I turn the lights on it returns to the swaying unless the engine is higher than 2000RPM, which gives a steady light and meter...Any Ideas? The voltage meter is new and the alternator seems fine and keeps everything in order and the battery charged. Help?
Old Apr 28, 2006 | 03:58 PM
drof46's Avatar
drof46
I would suggest getting the alternator tested anyway since this is usualy free at your local parts store. Also the article whiter whites and britter brites was suggested on another post. I did it last weekend and it is an easy upgrade.
Old Apr 29, 2006 | 11:21 AM
theswen's Avatar
theswen
Ok, I'll do that, since the alternator is probably original or very old! I have a feeling there is more to it...Maybe. Thanks!
Old Apr 29, 2006 | 05:02 PM
jd_sylvia's Avatar
jd_sylvia
The waving alt guage is usualy the voltage regulator. I changed over to an electronic voltage regulator and it works like a champ. I also installed relays with heavier wire to my H4 headlights and am very happy with the results.
jd
dyxie64
Dec 18, 2023 02:44 PM
Rockaholic
Aug 25, 2011 12:04 PM
cornking
Jan 26, 2011 07:31 PM
moto_stevo
Jan 7, 2009 03:00 PM
Aramis
1983 - 2012 Ranger & B-Series
23
Sep 29, 2006 11:43 PM
