Cleaning injectors?
Old Aug 23, 2011 | 12:33 AM
j250hd's Avatar
j250hd
Cleaning injectors?
Got a question for those of you who pulled your own injectors and cleaned them while they were out. I watched a chevy technician take injectors out of a duramax and put them into a buratic acid? ( I think that's the acid they used) and a water solution. It seemed to really clean them off, looked brand new. Can we do this with our injectors? Or is there a better way?
Old Aug 23, 2011 | 01:15 AM
Dutch Semi's Avatar
Dutch Semi
Not sure about cleaning injectors but, I can tell you it is called muriatic acid.
-Joseph
Old Aug 23, 2011 | 03:20 PM
Brown Falcon's Avatar
Brown Falcon
I'd talk to Jim, he owns the Rosewood Diesel Shop and builds injectors... are you talking about cleaning the inside or the outside?
Old Aug 23, 2011 | 04:28 PM
j250hd's Avatar
j250hd
Outside I guess. He just dropped them in the bucket of solution and it started fizzing and cleaning them.
Old Aug 23, 2011 | 06:56 PM
F350-6's Avatar
F350-6
I guess that would make them look pretty, but what do you think you'll accomplish by doing this? The outsides will get dirty again when you stick them back in and start the truck up.
I would just worry about the injector internals, which is something you're better off letting someone like Jim look at when needed.
Old Aug 23, 2011 | 08:07 PM
fordpride's Avatar
fordpride
I'm with Chris on this one if it's eating the grim off the outside just think what it is doing to the orings inside of the injector
Old Aug 23, 2011 | 08:13 PM
j250hd's Avatar
j250hd
That's what I was wondering, I know the internals on our injectors are a little bit more complex. Just wondering if it would make it that far in? I was thinking more for just giving the nozzles a good cleaning.
Old Aug 23, 2011 | 10:27 PM
Brown Falcon
There's no way to clean a clogged injector nozzles on these, holes are too small. Plus you'd have to completely disassemble the entire injector just to get to them. The nozzle is the last part to come out (trust me, I know from experience)
Only way to test them is a flow test, which Jim can do, and if it's clogged you need a new one.
genscripter
21
Nov 22, 2016 11:03 PM
FordOwnerJoey
Jan 21, 2014 09:21 PM
VONxRUBENxLA
Modular V10 (6.8l)
13
Aug 15, 2012 03:29 PM
07 F250 Aggie Mobile
Jan 20, 2011 01:11 AM
guitar_199
Jul 23, 2008 07:51 AM
