Sponsored by: Real Truck
DOOR MIRROR
Old Aug 22, 2011 | 08:39 PM
betsardinski's Avatar
betsardinski
DOOR MIRROR
I'm wanting to replace my door mirror on my 1999 Ford F-250 Super Duty Diesel, 7.3 L.
On the inside of the door frame (near where it is hinged to the truck) there are 3 rubber bushing inserted in holes (probably not what they are called) and when I remove the top and bottom one, each has an easy nut to remove (mirror will not come off at this point).
Removing the middle rubber bushing, leaves me with a fitting(???) I've never seen before.
<VAR id=yiv845016467yui-ie-cursor></VAR>
It's shaped something like a wing nut, only with 3 wings instead of 2 and it fits into a slotted part of the door frame. It appears like you have to pull it towards you (spring loaded?????) (which would get it out of the slotted area) in order to loosen (turn) it.
The problem is the hole is only about the size of a nickle coin and I don't know what you could use to get at it, if this is what's still holding the mirror in place.
I would appreciate any suggestions someone may have on how to remove this mirror.
Thank you and have a great day.
Old Aug 22, 2011 | 09:05 PM
BigAlsPSD's Avatar
BigAlsPSD
First off Welcome to FTE! Although I don't know the part that you speak of, there should only be 4 nuts holding the mirror in place? Behind the top rubber grommet, the bottom rubber grommet and behind the "Tape" on the window side, here's a pic for reference,
Old Aug 22, 2011 | 09:06 PM
dchamberlain's Avatar
dchamberlain
There is a black plastic cover rearward of the 3 rubber grommets. It just snaps off. Under it is some insulating tape and under that are two holes with two more nuts. Take those off and the mirror will come loose.
Old Aug 22, 2011 | 09:37 PM
betsardinski
MIRROR
Thank you very much for the explanation on how to remove my mirror and the great picture that came with it, showing me how.
Old Aug 22, 2011 | 09:40 PM
ak-angler's Avatar
ak-angler
And, welcome to the forum!
Old Aug 22, 2011 | 09:45 PM
betsardinski
Thank you. Hopefully I'll be able to help someone sometime.
66with352
Dec 22, 2017 12:07 PM
raytasch
Feb 14, 2014 07:56 PM
andgott
17
May 6, 2012 08:27 PM
67catmando
Sep 10, 2010 06:13 PM
