Video: Timing Chain Tensioners or Cam Phasers
whoops, sorry, my 5.4L had the following:
- #4 and #6 fuel injectors replaced (extended warentee).
- #6 COP
- and ALL spark plugs (with new one peice design).
But just got it back from the dealership and they said #4 has definetly low compression.
I am suspecting the rest of the fuel injectors are lacking in tip-top shape and performance... wish Ford would replace them all for me.
But now I might be leary of the CAM PHASER/s.
(would a bad cam phaser cause ONE cylinder to be bad?)
ps. I am calling Ford hotline tommorrow... this stinks!
TONY
- #6 COP
TONY
I can not get this truck to throw a "check engine light" if I bet it with a stick.
Only one time it threw a code (when the COP finally gave out going up a hill).
But after that was fixed, it is not telling me what is wrong with it.
I may take it to another dealership to get a second opinion...
I didn't call Ford hotline yet, cause I don't want to be a pain in the ***, but it may come to that point.
My truck isn't even drivable, since I live on a hill and it has absolutely no power and I don't want to mess anything else up inside the engine...
Tony.
Yep its normal. Here is Ford's message:
21574 4.6L 3V/ 5.4L 3V ENGINE TICK/RATTLE FROM VCT 800-1200 RPM - DO NOT ATTEMPT SERVICE
2009-2010 F-150 WITH 4.6L 3V, 2005-2010 F150 WITH 5.4L 3V,2005-2010 MUSTANG WITH 4,6L 3V, 2005-2010 F250, F350 WITH 5.4L3V, 2006-2010 EXPLORER/MOUNTAINEER WITH 4.6L 3V ENGINE, 2007-2010 SPORT TRAC WITH 4.6L 3V ENGINE, AND 2005-2011 EXPEDITIONS AND NAVIGATORS WITH 5.4L 3V ENGINES. SOME CUSTOMERS MAY BE CONCERNED WITH TICK/RATTLE NOISES FROM THE VARIABLE CAM TIMING (VCT) ON LIGHT TIP-IN ACCEL BETWEEN 800-1200 RPM. THIS CONDITION MAY BE MOST NOTICEABLE OPERATING VEHICLE IN CONFINED AREAS SUCH AS A DRIVE-THRU. THE NOISE IS ELIMINATED WHEN VCT SOLENOIDS ARE UNPLUGGED. THIS CONDITION SHOULD BE CONSIDERED A NORMAL CHARACTERISTIC OF THE ENGINE. DO NOT ATTEMPT ENGINE REPAIRS TO CHANGE THIS NORMAL CONDITION. THIS CONDITION DOES NOT AFFECT PERFORMANCE OR DURABILITY OF THE ENGINE.
Thanks,
Justin
shadetreevanguy
03-01-2018 08:11 PM
