Cam Tensioners
Old Jun 3, 2005 | 09:30 AM
edillen's Avatar
edillen
Cam Tensioners
How do you know if the cam tensioners on your engine need to be replaced? My truck has the slight "dieseling" noise coming from the engine but nothing real loud. It seems to have okay pick-up when I put the gas into but nothing neck snapping. I initially attrubuted this to the electronic thottle but now I am not sure. It definitely does not feel like a 4 banger in there but how does one know?
Old Jun 3, 2005 | 09:33 AM
edillen's Avatar
edillen
sorry guess I meant cam phasers instead
Old Jun 3, 2005 | 03:11 PM
piercede's Avatar
piercede
Cam Phaser
If you had the cam phaser issue you will hear a definate knocking or tapping sound coming from either the drivers side or passenger side. I had the problem on the passenger side and when you stuck your head in the front wheel well you could definately hear the knock.
I also have the slight diesel sound you are referring too, sounds almost like a loose chain I guess would be a way to describe it. As far as I know that is normal for these engines.
mattnj
Sep 22, 2016 09:34 PM
Mikerage
1997 - 2003 F150
30
Jul 29, 2016 02:59 PM
eigenvector
1983 - 2012 Ranger & B-Series
Sep 25, 2006 09:44 AM
gto78
Jun 26, 2006 09:41 PM
oldogy
Nov 29, 2001 08:10 PM
