Rear main seal replacement
Old Aug 22, 2011 | 12:41 PM
dakonthemountain's Avatar
dakonthemountain
Ok, so I have the shop manual, though not with me. It really seems pretty straight forward (2 piece seal) and not that difficult, but I've decided I don't want to mess with doing the seal myself so I've called a local mechanic. They quoted me 8 hours!!! How can this be? I don't recall anything very complicated. From memory of reading the shop manual, other than dropping the oil pan/pump, undoing the bolts, dropping the crank a little under 3/8" inch, popping the old out, the new in and closing it all up what more could there be? Am I missing or forgetting something here? Help! My back is a bit torn up and I can't do this myself this time (I think that steering gearbox replacement did me in! )
Thanks guys!
Dak
Old Aug 22, 2011 | 03:27 PM
dakonthemountain
Just to clarify, I'm not asking anyone to physically help me with this! Only information on what I may be missing... Anyone?
Thanks!
Dak
Old Aug 22, 2011 | 03:34 PM
n3vyk's Avatar
n3vyk
They are probably going by a "Flat Rate" book that tells them how many hours to charge. If it is a 2WD I do not think you can get the pan off without raising the engine some.
Old Aug 22, 2011 | 03:54 PM
dakonthemountain
It is a 2wd, but my Ford factory shop manuals do not say anything about raising the engine! I also think there MUST be a mistake in the book. Even the mechanic I spoke to said there must be, but he has to go by the "service writer" instructions. Geesh!!!
I hope to hear from someone here that has replaced their own seal with the specifics.
Thanks!
Dak
Old Aug 22, 2011 | 04:50 PM
jeff14346's Avatar
jeff14346
I checked ALL Data, goes back to 1982, flat rate time is 4.1 hrs
maybe they are trying to pull the trans to do the repair as if it is a one piece rear main?
Old Aug 22, 2011 | 06:35 PM
dakonthemountain
Thanks Jeff14346. Not sure where they are getting their info, but I'll let them know! Thanks again!
Dak
stumpbuster
Oct 16, 2012 10:37 AM
4x4jedi
Jan 15, 2011 11:02 AM
80FlareSide
19
Oct 7, 2010 11:02 PM
EJEther
Feb 5, 2003 06:11 AM
85351ho
Sep 26, 2002 02:03 PM
