Rear main seal??
Old Jan 14, 2011 | 03:53 PM
4x4jedi's Avatar
4x4jedi
Rear main seal??
Can it be changed via oil pan is trany removal my only option??
Old Jan 14, 2011 | 03:57 PM
jowilker's Avatar
jowilker
What engine are we referring to bro?
John
Old Jan 14, 2011 | 04:10 PM
4x4jedi's Avatar
4x4jedi
Sorry... 360. I'm hoping it's a 2piece kind that I can get from the pan side of things when I do my oil pump next week. I'm just trying to get parts ordered now.
Old Jan 14, 2011 | 04:49 PM
BobbyFord's Avatar
BobbyFord
Yes, you can do it without removing the trans. It is a two piece seal. If it hasn't been replaced, it will be a rope type seal. Replace the rope type seal with a two piece Fel-Pro rubber seal. It's also not necessary to "drop" the crank down a little by loosening other main caps.
Old Jan 14, 2011 | 06:35 PM
Phil105's Avatar
Phil105
This is GREAT NEWS INSTI - - - just discovered my rear main is leaking also - been dreading that job - glad to hear the tranny doesn't have to be pulled. THANKS
Old Jan 14, 2011 | 06:39 PM
4x4jedi's Avatar
4x4jedi
Love it!!! Thanks a lot instigater!
Old Jan 15, 2011 | 05:33 AM
jowilker's Avatar
jowilker
Rear main seals on FEs get blamed for leaking when it's not. Valve covers & intake manifolds are notorious for leaking, while having air flow push the leaking oil down the back and the ol rear main gets blamed.
I just had this reinforced on my truck this year when it took 3 gasket attempts on the drivers side to get it stopped. They leak bad bad too.
If your truck has a C6 pull the inspection cover and look at the seal area, most times it will be dry.
FE rear mains can leak but rairly do.
John
Old Jan 15, 2011 | 07:03 AM
Talltruck's Avatar
Talltruck
Also make sure the PCV system is working correctly; these motors need to have something to relieve the pressure so they aren't pushing oil out everywhere.
Old Jan 15, 2011 | 09:47 AM
4x4jedi's Avatar
4x4jedi
I did the whole top end not to long ago and it's dry up hi. The front 3/4 of the oil pan is dry too. The 360 smokes a good bit when cold and choked but cleans up after a little bit. I'm loosing about a quart of oil for every 1/3 tank of gas. I am a fan of the skinny pedal so I am hard on it. I have a 4spd so I'll pull the lower bell cover and take a look befor I commit to changing the rear main.
The bottom end is pretty warn out. I'll be throwing bearings and a high volume oil pump in there next weekend. I would like to get some more life out of the old 360 befor I'm forced to throw a ton of $ at my 460. I want to build it right and not rush it with cheep parts.
Old Jan 15, 2011 | 10:34 AM
TigerDan's Avatar
TigerDan
If it's 2wd getting the pan off with the engine in place is no easy job, the engine will have to come part way out to get enough clearance.
Old Jan 15, 2011 | 11:02 AM
4x4jedi's Avatar
4x4jedi
Hence why it's the last thing on my list for this motor.
I have been contemplating cutting out the x-member ant building a new better one. I hate dumb designs. It's a mess to change the oil too so a new x-member sounds good to me.
351slug
Offroad & 4x4
Mar 16, 2013 10:11 PM
Irish816
Offroad & 4x4
17
May 19, 2010 08:08 AM
Offroad & 4x4
Dec 9, 2006 09:03 PM
4x4x4x4
28
Dec 16, 2002 01:54 AM
CustomCab4x4
Feb 3, 2002 02:20 PM
