Side steps
The hoop steps are no good because they just mount to the rockers and cause alot of stress on them.
The other options are the true running boards, but those don't look very good most of the time.
Then there are nerf bars. I have had them and don't care for these either. The Westin nerf bars I had mounted to part of the cab and a body mount and the frame. The problem was than when the frame flexed a little when even turning into a steep driveway, the nerf bars rear most mount would start to come loose.
While it would be nice to have, I wouldn't try mounting pull handles on the pillars. I bet you will just end up with broken pillar trim. While we are taking about these, please do not drill holes in the exterior of the cab for the awful chrome handles.
And with the except of a SMALL amount of aftermarket stuff, nothing is truly better than OEM parts...
Now....
As for Jaime's hand grips....Here's a alternative solution...
Find a set of grips from a newer truck, measure the holes, etc...And remove the trim panel to see where the metal best fits....IIRC, the metal has a sharp angle in it, making it hard to mount those grips on...
But a SMALL amount of metal work in the form on a set of mounting tabs would work perfectly....Then simple use a hole-saw attachment, pop a couple holes in the trim panel....
Feed the grips' end points/mounting bracket areas through....Mount them to the metal tabs welded onto the A-Pillar...And Then re-attach the trim panel...
VOILA!....Actual hand grips....
As for the steps....Rocker mounted ones...Stay FARRR away from...
I found a great used set on (almost locally) craigslist, but it took me nearly a year to locate. I have also tried to find a replacement set of mounting bars, but no luck. Mine are in good (not great) shape so I'm going to have them bead blasted then sealed with rust preventive paint before I mount them. If they are still rough after the beadblast, I will have some support tubing welded in for strength. This style of step looks the best on this year of truck, hands down.
yet another project LOL
