do you have to...
Old Aug 22, 2011 | 07:33 AM
tofargone's Avatar
tofargone
do you have to...
In the morning i have to let my truck worm up fore like 10 minutes or it just don't have any power at all. Then it has to wind up to 1600-1800 then it will take off like a bat out of hell how do i fix this i see some videos of trucks with grate throttle responce thanks for the help
Old Aug 22, 2011 | 07:51 AM
Tim_M's Avatar
Tim_M
Sounds like an issue I had but not as bad, if your stock you may want to check if the catalytic converter is starting to plug up. Too much back pressure on the turbo and it doesn't spool well at low RPM. I'd also check all the connections to the turbo.
Old Aug 22, 2011 | 08:05 AM
tofargone's Avatar
tofargone
Cool i will do that i was going to strait pipe it soon anyway so i gess now is the time to do it. Is their anything else that could be the problem
Old Aug 22, 2011 | 08:21 AM
tofargone's Avatar
tofargone
Old Aug 22, 2011 | 01:36 PM
rdunagan's Avatar
rdunagan
injectors could be going south
Old Aug 22, 2011 | 02:21 PM
tofargone's Avatar
tofargone
Noooo that's not cool lol still better than i thought
Old Aug 22, 2011 | 02:24 PM
npccpartsman's Avatar
npccpartsman
+1 ^^^
I'm thinking you're suffering from some injector stiction. What are your oil change intervals and what oil and filter do you run?
Old Aug 22, 2011 | 03:38 PM
rdunagan's Avatar
rdunagan
^^^^ what he said that info might help. check out this stuff it might be worth trying before you fork out all that money for injectors. REV-X Oil Additive it has helped many of people just like yourself with the same problem
Old Aug 22, 2011 | 05:09 PM
wulfman's Avatar
wulfman
Mine did same thing when i had injectors going out , would not run till warmed up,
Old Aug 22, 2011 | 09:40 PM
BLADE35's Avatar
BLADE35
check your FICM voltage when cold
I to had this problem but mine was leaky injector orings they wouldnt seal till warmed up it ran ruff and wouldnt shift right and would even misfired reringed the injectors and problem solved
does your oil smell like diesel fuel mine was making a qt every 2 weeks
synthetic oil may help
Old Aug 22, 2011 | 11:01 PM
tofargone's Avatar
tofargone
Motercraft filter rotilla t6 every 5k or less i usually do it when my wife s excursion is do thanks all fore the help i was afraid it was rings or something like that
Old Aug 23, 2011 | 01:03 AM
matty169's Avatar
matty169
Do ficm test and.......
Test ficm cold, key on, cranking and at idle. Check injector contribution with IDS and make sure to turn off compensation, COLD and in drive or reverse. You WILL find your problem. And if it is the injector contribution REV-X WILL HELP.
JaySVX
Jul 21, 2013 10:37 PM
75Three90
Mar 24, 2013 07:14 PM
AndeyHall
Jul 5, 2011 05:53 PM
IDPisan
26
Jun 9, 2007 02:47 PM
lovemy150's
Sep 21, 2006 12:05 PM
