1978 - 1996 Big Bronco
Bronco knocking when engaged in 4X4
Old Aug 21, 2011 | 10:31 PM
bamafarmboy's Avatar
bamafarmboy
I have a 1989 full size bronco with a 351 and C6 trans. When I got it the rear end was out and you could only move it with the front wheels engaged. It made a little noise but I saw that it needed a U-joint so I didn't worry. I swapped out the rear end( and yes it was the right ratio) and fixed the U-joints and now it makes a knocking sound when it's under pressure in 4 wheel drive. It sounds like its coming from the driver side. I swapped out the manual hub with one that I knew was good and no change. I took the driver side axle out and checked the spines, the u-joint, and the wheel bearings. All where good. It only does this when the transfer case is engaged and the hubs are locked. I can unlock either one of the hubs and the sound stops. I need some thoughts. Any help would be appreciated.
Old Aug 22, 2011 | 05:37 AM
b4hntn's Avatar
b4hntn
this is a silly question but it has happenned. Are you front and rear tires the same size?
Old Aug 22, 2011 | 05:38 AM
b4hntn's Avatar
b4hntn
This is a silly question but it has happenned. Are your front and rear tires the same size?
Old Aug 22, 2011 | 05:45 AM
bamafarmboy
Yes I have a brand new set of all-terrians. I'm wondering if it is inside the t-case. Maybe chain sliping. Does this make any sense?
Old Aug 22, 2011 | 08:10 AM
Conanski's Avatar
Conanski
If the PO managed to break the rear axle it's entirely possible he also damaged something in the front at the same time, I'd suspect a chipped tooth on one of the gears in the front diff or a broken spider gear, etc.
Old Aug 22, 2011 | 04:48 PM
andym's Avatar
andym
I would try to isolate the noise more. Drive it at low speeds and see if it still makes the noise. You should be able to pinpoint it better. How do you know the ratios are the same? Are you relying on the door sticker or axle tag on the donor being correct? Or did you physically count the ring and pinion teeth?
Old Aug 22, 2011 | 06:34 PM
bamafarmboy
1.I have considered that they damaged it during the time that the rear end was out and they were driving it with the front end.
2.The ring gear in the rear was chewed to hell and back when I got it. I have not looked inside the inspection plate in the front end. When I changed the rear end out I counted the teeth and made sure that the rear end I replaced it with was correct. I think it had 3.55 gears.
3. I've tried to isolate the noise and it sounds like it's coming from the front driver side. If it were in the t-case the sound should come from under the seat. I have had the complete driver side apart and everything looks good. I've had the axle out and the spines look good. The U-joint is not in a bind and I can't find anywhere that the shaft is hitting anything.
I guess the next thing the check is the front diff.
Old Aug 22, 2011 | 06:53 PM
andym's Avatar
andym
But now you're making the assumption that the front axle has 3.54 gears. Not necessarily a good assumption.
If you spin the front driveshaft by hand, do you hear anything out of the ordinary?
Old Aug 22, 2011 | 07:28 PM
bamafarmboy
I can spin the shaft and everything feels good. However, I might could jack the front end up and turn it all with the hubs locked and this might tell me if the problem is in the front diff.
And yes I know the rule is that you assume nothing, but with all the information I have on the bronco, I'm very certain that the front and rear are factory.
Old Aug 25, 2011 | 07:12 PM
bamafarmboy
I drove the bronco the other day and stuck my head out the window to take a look at the front wheel. When it pops the front wheel snaps from side to side. The problem has got to be in the front driver side wheel.
alienmarshall
May 28, 2016 06:29 PM
wittwayne
Sep 12, 2013 03:41 PM
bamafarmboy
Aug 22, 2011 06:11 PM
1980F15049
Nov 24, 2009 11:31 AM
NVETHIS
Bronco II
Jan 30, 2004 12:21 AM
