Bronco knocking when engaged in 4X4
Old Aug 21, 2011 | 10:20 PM
bamafarmboy's Avatar
bamafarmboy
I have a 1989 full size bronco with a 351 and C6 trans. When I got it the rear end was out and you could only move it with the front wheels engaged. It made a little noise but I saw that it needed a U-joint so I didn't worry. I swapped out the rear end( and yes it was the right ratio) and fixed the U-joints and now it makes a knocking sound when it's under pressure in 4 wheel drive. It sounds like its coming from the driver side. I swapped out the manual hub with one that I knew was good and no change. I took the driver side axle out and checked the spines, the u-joint, and the wheel bearings. All where good. It only does this when the transfer case is engaged and the hubs are locked. I can unlock either one of the hubs and the sound stops. I need some thoughts. Any help would be appreciated.
Old Aug 22, 2011 | 06:50 AM
Lazy K's Avatar
Lazy K
Hard to say. Are all three axle shaft universal joints good? Are the axle pivot (hinge) bushings good? Is the front driveshaft slip joint lubed and free to move?
Old Aug 22, 2011 | 06:11 PM
bamafarmboy
The pivot bushing? Is this the little small bearing inside the spindle?
wittwayne
Sep 12, 2013 03:41 PM
bamafarmboy
1978 - 1996 Big Bronco
Aug 25, 2011 07:12 PM
ErrorS
18
Dec 4, 2009 08:40 PM
suthrnslew
Dec 8, 2008 02:30 PM
serelle1
Oct 19, 2003 07:25 AM
