confused
Old Aug 23, 2011 | 08:36 PM
  #31
Bonanza35's Avatar
Bonanza35
SC< SuperChip tuner. Sounds like you got it going. Report back on the power after you get to drive it on the oper road. Chet
Old Aug 24, 2011 | 04:35 PM
  #32
DKF350's Avatar
DKF350
ok i got to drive it around today i got my tags. and its running great except for once i step on it and let off i dont here the injectors clicking until it goes below 30. is that ok.... and when i put it in high idle it misses but every other postion is good. i have to run it on street because stock just doesnt sound right do you think they did the chip wrong. i also feel like it shifts wrong.... any thoughts.
Old Aug 24, 2011 | 04:46 PM
  #33
Kwikkordead's Avatar
Kwikkordead
Cannot offer you any insights on the missing other than you might have an injector or two that are out of tolerance.
It happened to me on some rebuilts that I installed one time and never could get the motor to run right until I installed some NEW Alliants.
After that it ran perfect.
And your injectors are shut off on decel to save on fuel. Part of the programming and the silent injectors above 30 are normal operation.
Same programming as the gas engines when the computer shuts off the injectors for decel.
Old Aug 24, 2011 | 04:47 PM
  #34
BigAlsPSD's Avatar
BigAlsPSD
That is correct, your torque converter is locked and it should be dead quiet when you let off and the TC is locked. As well as the tuning changes for fuel. Once it releases it will chatter away.
Old Aug 25, 2011 | 12:08 AM
  #35
DKF350's Avatar
DKF350
what if i went and did a buzz test and they all did great? cant explain it why it misses
Old Aug 25, 2011 | 12:14 AM
  #36
BigAlsPSD's Avatar
BigAlsPSD
The buzz test is checking the electrical side of the injectors, you are not getting any codes right? Have you ran the truck enough to work out the air in the systems?
Old Aug 25, 2011 | 12:59 AM
  #37
DKF350's Avatar
DKF350
no codes and my buddy said ill probly get some hitch ups for like 200 miles or lesss depends on how i drive it i have it on street right now because it runs best on street not stock
johnny diesel
16
Apr 24, 2014 09:02 AM
briancooper
Dec 29, 2012 10:52 PM
XHunter
Jul 18, 2012 05:47 PM
smokineaglev
Dec 29, 2008 10:44 AM
caseydudem
Dec 14, 2007 03:11 PM
