Still need some help
Old Dec 12, 2007 | 01:58 PM
caseydudem's Avatar
caseydudem
Alright all you problem solvers. I started a new post on this one becasue I think everyone got confused on the last one. Here is what going on.
Problem: Rough idle, start and stops with a clunk(Hard in other words) It starts and stop fast like it should but with a clunk sound. Fuel milage is a lot worse then before.
Whats new: I changed the fuel pump to a brand new ford oem, and I decided to do the IDM mod well the IDM fried and I ended up having to get another, so I went with a SD IDM. When I put that in I still had a problem with the connection to the valve cover gaskets. The truck wasnt getting enough of a connection to run, so I stuck my little screw driver in and bent the clip down to put more preasure on the connection and it worked for the most part.
previous ideas: fuel presure was checked and sits at 70-74 psi. no codes read out on the scanner. Another one suggested ICP. I didn't disconnect it, but it was completely dry around it so I didn't think that was it.
Ideas: Maybe injectors have went, or could the IDM have burned the gaskets, or connections? I cant test the injectors with my scanner no buzz test option.
Any ideas or suggestions would be great
Old Dec 12, 2007 | 04:34 PM
Action4478's Avatar
Action4478
The rough idle can be an HP oil pressure(ICP) ..Or ,I just learned recently, that the FPR screen may be plugged & not removing air from the fuel....
You need a good PSD scanner, Like A E or Snap On , , to limit the guessing....
How old is the IPR?...
The ICP could still be bad ,
even though it is not leaking....
Old Dec 13, 2007 | 10:37 AM
caseydudem's Avatar
caseydudem
Thanks. I dont know how old they are. Both the ICP and the IPR came with the truck. I have had the truck for about 25,000 miles. The FPR screen was just cleaned when I put the fuel pump in.
Is there away to check each of those senors, not just a visual? I would really like to figure this one out. You dont think an injector went south? I dont know how old those are either.
Old Dec 13, 2007 | 12:06 PM
MADVAN's Avatar
MADVAN
Can you describe this clunk better? When/all/hot /cold/1 clunk/many clunks (knock)/smoking. Only turning off/cranking?
Possible cracked ring gear/flywheel?
A buzz/cont test would help.
Bill
Old Dec 13, 2007 | 01:00 PM
caseydudem's Avatar
caseydudem
Only one clunk, and its right when it fires up or stops. The truck does smoke some on start up. I think the injectors are worn, but the clunk happens when it is hot or cold.
Old Dec 13, 2007 | 01:12 PM
MADVAN's Avatar
MADVAN
Have you checked the Wheel and bolts for the TC?
I would also do a start/shutdown with belt removed.
Bill
Old Dec 13, 2007 | 01:18 PM
caseydudem's Avatar
caseydudem
What do you mean by TC? Torque converter?
Old Dec 13, 2007 | 01:28 PM
MADVAN's Avatar
MADVAN
Yes.
The plate has been known to crack at the crank, And also oblong the holes at the TC from being to loose.
Iam not sold on the clunk and ruff idle being one issue.
Can you hear or feel what the general area is of the clunk.
Turn it off while still in gear. See if it changes.
Bill
Old Dec 14, 2007 | 02:38 PM
caseydudem's Avatar
caseydudem
I have accidenty done that a few times. I will try it tomarrow. If it goes away that means it should be okay, or what should I be trying to notice? I can also take the belt of to and see what that does. Thanks for the help.
Old Dec 14, 2007 | 03:02 PM
caseydudem's Avatar
caseydudem
I have another idea that came to me today. Can this be something to do with the PCM? Could the IDM that fried have done something to make the PCM bad? I have noticed an unsual amount of movment in my gauges. I have already said that the idle is rough, and it is between 500 and 700 rpm mostly when cold, but the rest of the gauges kinda move randomly. Not a lot but they didnt at all before. It was just something I noticed the last couple of days.
Old Dec 14, 2007 | 03:05 PM
MADVAN's Avatar
MADVAN
Just trying to find where the clunk comes from.
Have someone turn off the truck while your under the hood and truck.
You can remove the belt. If clunk goes away you would know its in the accessories.
Bill
Old Dec 14, 2007 | 03:11 PM
caseydudem's Avatar
caseydudem
Okay, I will give it a shot tomorrow. The results should help us anyhow. Maybe we have two problems.
