turbo block...
Old Apr 2, 2003 | 10:52 PM
broncr's Avatar
broncr
Exclamation turbo block...
So I want to build a "turbo" block. I start with an old block, worn but good (250K & never been bored) ,'tank&'flux and align bore (if needed), true, bore (if needed - minimum/ how much?) ; forged (?) steel crank- turn(minimum) if needed; steel (?) rods, forged aluminum dished pistons - what compression ratio? Stock wrist pins? What bearings? Now I have a starter turbo block... I think, at least.... with all those "?"'s answered, I think I have a start. Did I miss something? Please let me know...
'member, I'm runnin' at 6K base altitude....
Old Apr 3, 2003 | 06:16 AM
StrangeRanger's Avatar
StrangeRanger
turbo block...
How much boost? It makes a difference. For 6 psi or so, stock pistons are OK as are stock conn rods fitted with ARP fasteners and a prepped stock crank. If you're going up to 10 PSI you need to upgrade the pistons and above 14 or so you'll need to be putting in aftermarket rods and a steel crank.
There's some discussion about whether forged or hypereutectic pistons are better for a boosted engine
Old Apr 3, 2003 | 09:51 AM
wildjon300ci's Avatar
wildjon300ci
turbo block...
Find you an HD motor and use the stok forged pistons and rods. They will suit your needs just fine!
Old Apr 3, 2003 | 03:35 PM
StrangeRanger
turbo block...
All stock 300 rods are forged.
Old Apr 3, 2003 | 04:38 PM
Ford_Six's Avatar
Ford_Six
turbo block...
Stock rods, shot peened with ARP bolts, Forged pistons ceramic coated, stock wrist pins, balanced and stress-relieved stock crank, stress relieve the block, and, if it's available, have the coolant passages garnet blasted. It's kinda like sand blasting, but more efficient and less mess. It's not as expensive as it sounds, and looks to be well worth it. As far as boring, the minimum you can go to clean up the bore and get to a common size is all you want. There is only a negligible gain from extra boring. The one I am building is going to have rods from a 240, along with KB pistons with a very short compression height, and a ceramic coating. You want to keep the compression right around 8:1, and that is good for 8psi of boost on pump gas. Any more on either, and race gas might be necessary. The ceramic coating on the pistons generally runs around $180 for all six, and is more than worth it. The engine will live much longer, and the oil temerature will be greatly reduced.
Old Apr 3, 2003 | 08:49 PM
broncr's Avatar
broncr
turbo block...
'sounds like some very good considerations for a turbo 300 block, be it low, medium or high boost. 'preciate it.
PS... did the HD blocks come in a particular series of trucks/years? How do you distinguish one from a standard block?
Old Apr 3, 2003 | 09:04 PM
wildjon300ci
turbo block...
I stand corrected......and when I said use the stock pistons and stuff, I meant out of the HD motor. They are of a lower compression ratio and have a forged steel crank.
hustler54
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
Jan 30, 2014 01:51 AM
travelerest
Jan 18, 2011 08:54 PM
luckydoggy
Sep 25, 2008 04:55 PM
hoxiii
22
Oct 27, 2007 07:33 PM
swampo
Jun 30, 2004 10:00 PM
