brakes.... help please
Old Aug 21, 2011 | 01:30 PM
blackwidowrealtree's Avatar
blackwidowrealtree
i have a 1990 ford f250. 351 2wd with rear anitlock brakes in rear. and my front left brake line had a leak and i replaced it. note before i did this my brakes worked fine they were just leaking. so i put the new brake line in and then pumped the brakes to see fluid coming out and put it together. as i went to turn my truck i had no brakes. i bled the brakes and the brakes are the same as before. can any one help me.
Old Aug 21, 2011 | 01:41 PM
White 97 xlt's Avatar
White 97 xlt
Bleed in this order: Right rear, left rear, ABS module (on frame under drivers feet), right front, left front.. At no time let the brake fluid get low in the master cylinder , if it EVER sucks any air, START OVER!!!!
rpati1978
1997 - 2003 F150
May 7, 2012 05:58 PM
wmiller
Apr 30, 2008 01:39 PM
nudgey
Feb 3, 2005 02:11 AM
weldingfreak
21
Mar 23, 2004 10:43 AM
dab38
Aug 26, 2001 02:35 PM
