Modular V10 (6.8l)
off the line??
Old Aug 22, 2011 | 09:27 AM
DarrellinCeres's Avatar
DarrellinCeres
I just got my truck not that long ago and it's always had 4.30LS from the factory. I know a lot of people switch out to this or 4.5 something. Especially if you add bigger tires or do any towing. Lots of guys here who have done it and know will chime in.
Old Aug 22, 2011 | 11:48 AM
BigPigDaddy's Avatar
BigPigDaddy
Originally Posted by VONxRUBENxLA
do the 4.30's improve MPG?
They keep the RPM in the optimal range for power, which means it may be better for MPG because you don't have to use as much throttle to maintain speed (momentum). That is even more applicable when towing.
Old Aug 22, 2011 | 01:10 PM
SLE's Avatar
SLE
With 4.56 Limited Slip, 285/75/16s Bridgestone Revos, y-pipe mod, and a 5 star 91 octane towning tune it'll bark the tires pretty good from a standing straightline romp on the gas in 90 degree weather on asphalt with a half box full of fire wood. I would imagine it would eat up a set of stock tires in cooler weather with the tune modified a little and no wood in the box! I'm positive if it was a one wheel wonder it would roll smoke all day long.
Old Aug 22, 2011 | 01:11 PM
SLE's Avatar
SLE
forgot to add, the fifthwheel hitch was also in the box.
Old Aug 22, 2011 | 08:22 PM
BigPigDaddy
Originally Posted by SLE
With 4.56 Limited Slip....
You need to update your sig.
Old Aug 24, 2011 | 07:36 PM
vintagemoto's Avatar
vintagemoto
I can roast the Hell out of my tires just punching the throttle. Probably has to do with the tires though, 285/75/16 Federal Couragia M/T. Super soft mud tires...
Old Aug 25, 2011 | 08:52 AM
hunt1moore's Avatar
hunt1moore
It probably will in your case running 305-75-R16's.
Old Aug 25, 2011 | 04:25 PM
SLE's Avatar
SLE
Signature updated!
Old Sep 9, 2011 | 03:05 PM
Fosters's Avatar
Fosters
With my excursion, I couldn't spin the tires at all, even trying to do a brake stand it wouldn't work. Just too much weight over the rear. After the 5 star 91 perf tune, I was able to make it peel out around corners, but nothing to write home about. That had 3.73s. The new truck, reg cab 4x4 runs great I think; from the rpm I believe it has 3.73s as well but not 100% convinced. Main reason for that is, it'll spin all thru 1st if I mash it from a stop, depending on asphalt. Sometimes it'll start gripping at around 20-25mph on the speedo, sometimes it'll get to 35ish and when the shift comes up it gets traction. I can't wait to see this thing on a 5 star perf tune...
Old Sep 10, 2011 | 10:19 AM
rgbutten's Avatar
rgbutten
I've got the one wheel wonder. 2005 F250 stock 3V V10 4.10 RE 18" rims new Wild Cat's and it'll do as assumed anytime, anywhere. I'd much rather it didn't.
Old Sep 12, 2011 | 12:51 PM
kameronth's Avatar
kameronth
My stock V10 with BF Goodrich A/T 285/75 R16 will smoke both tires from a dead stop. I found this out last night when the PSD pulled next to me! Not sure what my stock gears are though.
Old Sep 12, 2011 | 03:53 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
howd u do? lol
Old Sep 12, 2011 | 04:01 PM
  #28
kameronth's Avatar
kameronth
It's actually my brothers PSD. He has a 03 7.3. From about 0 to 40 mph I pull ahead but once his turbo kicks in it's over for me. Once I get the cash together I will have to get a 5 Star tune and try again.
Old Sep 12, 2011 | 04:18 PM
  #29
VONxRUBENxLA
LOL right on im hoping to get one of those myself when $$$ gets right!! tell him let u get a turbo and do it again hahaha
'99F250
Modular V10 (6.8l)
Jan 12, 2018 07:08 AM
380tommy
Dec 21, 2015 12:38 AM
shawn55
Modular V10 (6.8l)
Mar 7, 2013 04:08 PM
Thenewboss
6.2L V8
27
Jan 21, 2011 10:58 AM
bralos
Mar 27, 2005 03:45 PM
