Replace power steering cooloer???
Old Aug 20, 2011 | 09:13 PM
xsportplyer's Avatar
xsportplyer
While I was tearing down my front end for my oil cooler rebuild I noticed my power steering cooler is pretty beat up. The plastic guard under my bumper broke and I believe driving through the corn fields last fall did the damage, seeing as i found pieces of stalk wedge between the slots on the cooler. What do you guys think? Will it still do its job or should I replace it?
Old Aug 20, 2011 | 10:10 PM
motocaptain's Avatar
motocaptain
On one of my powerstroke's I ruptured the cooler and.bypassed it to replace later, I never replaced it and never had a problem running without it...
Old Aug 21, 2011 | 05:44 AM
npccpartsman's Avatar
npccpartsman
I think you'll be OK as long as it's not leaking. You could get a fin comb and straighten the fins or, if you have the patience, a small screwdriver/knife combination will work almost as well. I have seen the PS coolers be nothing but an extra length of tubing run across the front of the truck with NO fins on them.
Old Aug 21, 2011 | 08:52 AM
69cj's Avatar
69cj
You could also replace it with a/m such as hayden or Imperial at 1/5 the cost and be on the safe side.
ghunt
Mar 3, 2020 01:14 PM
rv7plt
Nov 13, 2015 01:45 PM
abe
May 22, 2015 01:03 PM
someday
Feb 4, 2006 10:37 AM
