Ignition
Old Aug 20, 2011 | 05:11 PM
shamusliam's Avatar
shamusliam
Ignition
I need to know the voltage that should be going into my duraspark II control module. I have a new one and I don't want to fry it. Voltage at the coil with key turned to run is 7 volts. Voltage going into the old control module wired up with key in run is 12 volts. Isn't this too high for the module? How can I correct?
1978 F150 4x4 351m
Old Aug 21, 2011 | 01:15 AM
fmc400's Avatar
fmc400
MSEE
12 volts goes to the module. The voltage at the coil should be around 7 volts in RUN because there's a ballast resistor in series with the coil primary winding when the key is turned to RUN. Sounds like you're fine.
jshad101
15
Nov 11, 2014 05:50 PM
69BOSS429HEMI
Electrical Systems/Wiring
Mar 22, 2013 06:41 PM
mudder460
Feb 5, 2008 02:09 PM
Mud_Hunter
Nov 10, 2004 03:03 PM
JoeBlow
Jan 14, 2004 08:23 PM
