Sponsored by: Real Truck
Any Ideas?
Old Aug 20, 2011 | 01:47 PM
matty50330's Avatar
matty50330
Exclamation Any Ideas?
My 99 F250 SD 7.3L w/4R100 4X4 was running and driving fine until a starter wire failed and I pulled the flex plate inspection cover and found that my flex plate was going bad as well. I fixed the starting issue and the flex plate and had over sized 1/2" holes drilled and taped in the TQ Convertor to reduce the shearing of the bolts again. Then reasembled everything in the drivetrain with everything toped off. Now the Idle raise in all gears and lowers in park and nutral and will not move under its own power. The trans and convertor have less the 15,000 miles on them and I have no clue whats the issue. I thought maybe air locking some where but the trans pump should of pushed it out.
tonym17
Mar 20, 2019 12:01 PM
Old Yblockman
Jul 12, 2017 07:36 PM
bassdude
Mar 24, 2007 12:52 PM
mudinford
Dec 1, 2004 06:10 AM
