How many splines?
Old Aug 20, 2011 | 12:45 AM
Brown Falcon's Avatar
Brown Falcon
How many splines?
Stock '94 Dana 60 front axle.... how many splines are the axle shafts?
Old Aug 20, 2011 | 03:12 AM
joe_13894's Avatar
joe_13894
The inner axle has 35 splines going into the pumpkin. The outer axle has 30 splines going into the hub.
A very common upgrade for off-roaders is to change the outer axle shaft for a 35 spline model.
Old Aug 20, 2011 | 04:21 AM
Fullcrew7.3's Avatar
Fullcrew7.3
What Joe said.
Old Aug 20, 2011 | 10:42 AM
Brown Falcon
Ok thanks guys. I got confused seeing some stuff that said 35 spline, and some that said 30 spline, some that said upgrade to 35 spline...
So if you upgraded to 35 spline outer shafts would you need a different set of locking hubs?
Old Aug 20, 2011 | 03:12 PM
joe_13894's Avatar
joe_13894
Correct. The Dana 70 front axle used on a few medium duty trucks uses the same U-joint but larger outer shafts with 35 splines. What someone figured out is that you could put the Dana 70 outer shaft and hub on to improve the strength.
Unless you're putting giant tires on or planning on really hammering it off road I wouldn't worry about it. Just put regular hubs on it and you'll probably never break it.
Old Aug 20, 2011 | 03:18 PM
Brown Falcon
Cool. Thanks Joe.
Old Aug 20, 2011 | 07:18 PM
Fullcrew7.3
What Joe said. Again. Reps sent Joe.
Old Aug 20, 2011 | 07:19 PM
Fullcrew7.3
Nuts. the rep gods say no. Next time....
Old Aug 20, 2011 | 10:24 PM
Brown Falcon
I gave you some reps Joe!
schlepprock250
Oct 15, 2012 10:46 AM
idaho211
Jul 20, 2008 09:00 AM
blksiryder
Jul 31, 2007 12:30 AM
GeneStoner
Mar 5, 2003 05:10 PM
1ole4d
May 22, 2002 09:28 AM
