smoke on start without chip?
Old Aug 20, 2011 | 02:31 PM
Maxium4x4's Avatar
Maxium4x4
When you throw the programmer to it, again I am not familiar with the one you are using, injection is changed and how the VGT turbo vanes close and open along with EGR operation turned off. You could be moving more air with the programmer on start-up ect.
Is the blue smoke after sitting over night or at anytime? Seems injector related to me.
Old Aug 20, 2011 | 02:42 PM
baggedoutmazda's Avatar
baggedoutmazda
usually cold start after sitting all night. as long as engine is ambient temp on start it smokes until aprox 1/4-1/2 on temp gauge. warm restarts no smoke. never smokes with chip aside from minor puff on start.
Old Aug 20, 2011 | 02:51 PM
2006powerstroke90's Avatar
2006powerstroke90
This is how I would check for a turbo seal(atleast it worked on mine)
after driving it till operating temp and them some...let it sit over night, then dissconnect the down pipe to the turbo and look for oil.
Old Aug 20, 2011 | 03:02 PM
baggedoutmazda
i'm no expert but i have to shy away from turbo being problem as it had a complete new turbo aswell i swapped in another good known turbo just to see- still the same
Old Aug 20, 2011 | 03:32 PM
Rusty Axlerod's Avatar
Rusty Axlerod
The best plan would be to let them pull it down and inspect it. Sounds like it had a serious overheat and inspecting everything would ensure you have a reliable ride. It does have 3 compression rings + oil ring. One could be broke and still make good pressure.
With over 10k miles on it since the overheat a broke ring would have likely marked up the cylinder pretty good by now. Pull the head and insp cyl bore from the top (don't drop pan or pistons/rods. Disassemble heads and insp guides/seals.
Pull the valve cover and verify good oil flow. Inspect rockers and pivots. Insp the valve guides using the wiggle test and replace seals.
Load the pup and drive it. If it's seals it will stay about the same. If it's a ring or guide it's going to get worse.
I think oil at the manifold is a good indication of where the problem is. If it were a ring issue it would be much worse at this point and pressure would be down at least a few lbs on that cylinder. Also, oil would have to leak up into the cylinder after shutdown. I would verify there's good lp oil to that cyl and check the guide.
Old Aug 20, 2011 | 03:36 PM
Rusty Axlerod
Sorry, I was thinking of different options but didn't explain before hand or lable them.
Old Aug 20, 2011 | 05:41 PM
2006powerstroke90
I know you been doing injectors....could it be a damaged o ring possibly?
I know someone with a 7.3 it happened to
2006powerstroke90
Just telling you how to go about checking it thats all
Old Aug 21, 2011 | 12:43 AM
mohle's Avatar
mohle
No sense splitting heads if you still have the tuner in it. Could be injectors and the tuner changes the IPR, or it could be EGR and tuner turns it off. The tuner will just mask the problem.
Old Aug 21, 2011 | 09:49 PM
baggedoutmazda
i'm open to any advise/options anyone has. i really dont need chip in it, just didn't think that the tuner could change enough settings to stop the smoke if it really was an internal problem? ford tech says no to injector orings but who knows. its on my dime now as warranty ended in may.
birdogron
Aug 2, 2013 06:45 AM
chuckc417
Oct 21, 2011 07:28 PM
1wildman
Aug 22, 2009 09:35 PM
SpeedJunky
Jan 17, 2009 07:58 AM
jgarza250
Jun 29, 2007 03:50 PM
