Blue smoke
Old Oct 24, 2012 | 12:50 AM
birdogron's Avatar
birdogron
Blue smoke
OK, I've got 120,00 miles. I use a block heater for cold starts because if I don't, the motor sounds like it will grenade on me. It seems the injectors are the problem. At warm starts it's hard to notice the injector problem. I got a hold of Hot Shots Secret oil additive and there was definately smoke right at start up, but it had a different smell. The smoke went away. About a month went by and now I have blue smoke about 6 miles after initial warm up and while idling at that point. Also, I removed my chip to bring the truck back to stock (less catalytic converter.) The smoke is noticable for sure. EGR valve? Any ideas?
Old Jan 31, 2013 | 12:30 PM
dc3655's Avatar
dc3655
For the last month, I've had the same problem. It took 1.5 qts of oil to get me back to normal level on the dipstick today, so I know mine is burning the oil. I tried Rev-X in the last month and the problem only seemed to get worse. Did you figure your problem out yet?
Old Jan 31, 2013 | 04:03 PM
birdogron's Avatar
birdogron
Turned out to be the turbo dumping oil directly into the exhaust. $1500. repair. He replaced the old turbo with a rebuilt.
Old Feb 1, 2013 | 01:41 AM
dc3655's Avatar
dc3655
That's what I was afraid of. I'll be bummed if this turbo only lasted me 25k miles. I'm surprised that they aren't able to repair the turbo rather than just replacing it. I guess it's time to start saving up. Thanks for the help.
Old Aug 1, 2013 | 11:25 PM
birdogron's Avatar
birdogron
yeah I used super secret oil additive and it relieved the STICTION on the injectors. I did work.
Old Aug 1, 2013 | 11:33 PM
birdogron's Avatar
birdogron
Head Gasket?
OK, I had pressure tests done in two different places. My super diesel mechanic who I am related to can't find the leak. He did the rear end lift up for the egr and still can't find it. It has been narrowed down to the head gasket I think. My question is this. Has anybody heard of a head gasket sealant that works on high pressure diesels? 6L 2006. I researched online about several different ones and they all have something to say about their competition. I'm looking at $3500. including the cooler vs $130+ for the stop leak. I just can't see the stop leak working. I am using 1/2 gallon of water per hundred miles. Oil in water, no water in oil. Looking for some advice from a pro. Thank you for taking the time to respond. I am birdogron@yahoo.com.
Old Aug 1, 2013 | 11:56 PM
jswartz84's Avatar
jswartz84
If the stop leak will plug the headgasket leaks then what else is it going to plug up? I wouldn't do it but that just my opinion.
Old Aug 2, 2013 | 06:45 AM
mustang_309's Avatar
mustang_309
If you have oil in the coolant your oil cooler has failed, so I would get that repaired before you condemn the head gaskets. You will need to do a cooling system flush with some type of degreaser like simple green to get all of the oil out of the cooling system.
FourbynFord
Feb 19, 2016 02:12 AM
ssyputa
Jul 25, 2014 03:46 PM
ajbkid
Nov 18, 2010 09:55 AM
Groundpounder0331
Jun 2, 2009 09:25 PM
Reidicus
Jun 27, 2007 05:21 PM
