Sponsored by: Real Truck
Torque Steer/Radius Arm Issue?
Old Aug 19, 2011 | 10:34 AM
lrnad90's Avatar
lrnad90
I have a 2005 F250 Crew Cab 4x4. I have a very unusual issue related to what seems like torque steer. When driving down the road the truck tracks straight. If I step on the accelerator for a hard accelleration, the truck will pull left. When I let off the accelerator, the truck will pull right. This is not a subtle pull from the crown of the road or anything similar. The pull is not strong (as I can easily compensate while driving) but will significantly change direction of the vehicle (will almost change lanes over a short length of road).
The front end has been completely rebuilt (ball joints, tire rod ends, drag link, etc...). The only thing I can attribute to this would be the bushings on the radius arms or the bushing on the rear leaf springs.
Has anyone had a similar issue and how did you resolve it.
Old Aug 19, 2011 | 11:13 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
just for giggles, check your rear axle and make sure the leafs are tight and the springs perches aren't damaged
it's unlikely, but a loose/broken perch could let the axle shift on accell/decell. which would make the truck track left/right
also, double check the panhard/drag link. one of the end fittings could be loose. just a little bit of slop and you'll get that effect
needshave
16
May 17, 2019 12:52 PM
ErrorS
1978 - 1996 Big Bronco
24
Nov 21, 2010 05:02 PM
alvald83
Apr 3, 2010 01:48 PM
jimbo beam
Sep 16, 2006 09:49 PM
b1rdjx88
Nov 20, 2002 05:10 PM
