front end swim / clunk
Old Nov 10, 2002 | 04:24 PM
b1rdjx88's Avatar
b1rdjx88
My 82 f-150 2wd 300-6, has been having some handling problems on the road. It seems to wander on the road a little. Also, when I hit a bump, I often hear a "clunk" from the front drivers side. I have replaced the ball joints and the shocks and this helped the handling slightly. But the clunk is still there. The tie rods/ steering box are tight too.
I suspect the radius arm bushings (that rubber doughnut thing?). actually I think I remember notcicing they were sloppy when I jacked the truck up a while ago. How hard is it to change the radius arm bushings? Do I have to unbolt the whole front axle and the coil springs to get at them? Has anyone tried grinding the rivets off of the radius arm mounts so I can just remove those (then replace them with grade 8 bolts)?
thanks,
Alan
Old Nov 10, 2002 | 07:01 PM
1984_355w's Avatar
1984_355w
Yea grade 8's will be plenty strong. I would use a torch though to cut off the rivit heads. Will take maybe 1/8 the time that it would with a grinder.
Old Nov 20, 2002 | 05:07 PM
dpoelstra's Avatar
dpoelstra
yeah the clunk is from the radius arm
Old Nov 20, 2002 | 05:10 PM
dpoelstra's Avatar
dpoelstra
fordsuperduty250
Mar 2, 2013 11:27 AM
Manwith3fords
May 30, 2011 04:47 PM
88F-150pimp
Jan 6, 2010 12:42 AM
Manwith3fords
Aug 9, 2003 10:29 AM
BigMattXXL
Apr 10, 2003 09:47 PM
