MPG's Question
Old Aug 18, 2011 | 08:03 PM
Rosson03's Avatar
Rosson03
Talking MPG's Question
What you think about MPG
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1 itxtNodeId="1413"><!-- / icon and title --><!-- message -->Quote:
<TABLE border=0 cellSpacing=0 cellPadding=6 width="100%" itxtNodeId="1428" itxtHarvested="0"><TBODY itxtNodeId="1430" itxtHarvested="0"><TR itxtNodeId="1431" itxtHarvested="0"><TD style="BORDER-BOTTOM: 1px inset; BORDER-LEFT: 1px inset; BORDER-TOP: 1px inset; BORDER-RIGHT: 1px inset" class=alt2 itxtNodeId="1432" itxtHarvested="0">Originally Posted by wpnaes
What gear ratio are you runnin'? If a stock 3.73, moving to a higher numeric ratio should help your mpg's. Also, you're likely gettin' better than 5mpg 'cause your 37 (or 40) inch tire 'revolutions per mile' are less than stock, meanin' your odometer will read less than actual. So, maybe you're gettin' 7mpg, doesn't that make ya feel much better?
</TD></TR></TBODY></TABLE>
Anyone think it could help my mpg more from a 3.73 stock to the i think its a 4.43 gear with stock tires "285" i think
2000 Ford Excursion 6.8L V10 2wd: K&N air intake, Jet spacer, BBK Dual 65mm throttle body, Jet Mass air flow, Royal purple engine, Royal purple trans, Royal purple rear diff, Fitch Fuel Catalyst, ECT.......
Wanting y-pipe, flex-a-lite fan, jet 180 degree temp Thermostat, ect.....
<!-- / message -->
<!-- controls -->
Old Aug 18, 2011 | 09:21 PM
BigE2000's Avatar
BigE2000
Question
Does the Royal Purple help MPG?
Old Aug 18, 2011 | 10:14 PM
LivingLarge's Avatar
LivingLarge
Rosson, 265's are stock size.
430's are a more common upgrade for our Ex's.
If you have 285's you will benefit from the 430's specially around town driving. However you will lose a little mpg on highway driving.
Hope this helps,
Old Aug 22, 2011 | 05:56 PM
Rosson03's Avatar
Rosson03
I like it!
I think it shift so damn smoother and runs a tad bit better, i did it so i can run longer on the oil changes (saves money). the beast is a beast. i can get it cheaper than on the self price.
and all my other *gizmo* i have on there i did my mpg i am getting a tad bit over 13.2 mpg 35% city 65% hway..... if i used every drop of gas: 13.2 x 44gal = 580.8 miles for one tank. not bad for a V10 with 44gal tank
Dont pay attention to the lie-o-meter do the calculations by hand or cal.
just fill up (ouch!) reset your trip odd then drive till half tank, fill up again (ouch x2) then devide how many gallons it took to put back in there on THE FIRST STOP to the trip odd number
so it will be like this (miles drove) devide by gals = mpg
i am not good at explaining things lol
Let me know what you are getting!
**K&N air intake, BBK Dual 65mm throttle body, Jet Mass air flow, Jet spacer, Royal purple engine, Royal purple trans, Royal purple rear diff, Fitch Fuel Catalyst. took off my luggage rack, removed that big black rubber piece under the hood, ditched the running boards, took out the 3rd row seat and bass system**
Wanting: Banks Ultimate Power System for Towing & Work, flex-a-lite fan (i can get for $410) , jet 180 degree temp Thermostat, Performance coils and pulse iridium spark plugs.
2000 Ford Excursion 6.8L V10 2wd Odd +145000:
Rosson03
Sep 24, 2011 07:55 PM
95 F150 Dude
Mar 24, 2010 10:17 PM
ford-ex
Modular V10 (6.8l)
32
Nov 1, 2006 01:34 PM
guruatbol
Sep 27, 2003 07:13 AM
GSMcDermid
Mar 19, 2002 02:51 PM
