00 Explorer Steering Problem
Old Aug 17, 2011 | 07:39 PM
jsims813's Avatar
jsims813
Hey Guys,
Just replaced my drivers side upper control arm due to a bad ball joint and replaced the front shocks as well since they were due. The car was on jack stands and I had the key in the "on" position to turn the wheels and have access to the shocks. There was a small pop and the power steering cap was off partially. Now the front wheels shake when turned either on the ground or up on stands. Could this be that the power steering pump is bad? It still turns easily but has the shake. The pump was just flushed at 96,000 miles a week ago at the oil shop. Any help would be greatly appreciated.
Old Aug 17, 2011 | 07:54 PM
aquanaut20's Avatar
aquanaut20
The Rack has air in it, engine running, turn lock to lock until burped.. Philip
Old Aug 17, 2011 | 08:12 PM
jsims813's Avatar
jsims813
Thanks a ton Philip. Just did it for a few minutes with the wheels lifted and it seems fine now. Much appreciated.
Old Aug 17, 2011 | 08:33 PM
aquanaut20's Avatar
aquanaut20
Glad that worked, cheap and easy fix..(just like a baby). Philip
Wfb251
Feb 6, 2017 01:14 AM
Road Warrior 95
Jul 1, 2014 09:29 AM
dqdave1
Sep 30, 2009 12:16 PM
aerocolorado
Aerostar
Apr 22, 2005 01:53 PM
