Rear End Swap
Old Aug 18, 2011 | 07:31 AM
1800joedaddy's Avatar
1800joedaddy
I'm getting 23mpg with my 96 at 60mph, it drops to 16 @75. The rpms are the killer, just to many wasted cycles. BTW I have 4.10's and 235/85's, looking for a 3.55 or 3.08 r&p.
Old Aug 18, 2011 | 11:34 AM
dclack's Avatar
dclack
Yes, Ford started offering 3.73s in '97, but in the light duty F250, not the heavy duty OBS. If you had a '97 PSD (which only came in the HD) with 3.73s, then someone must have swapped them in, like I did. Finding a 10.25 with 3.73s will be nearly impossible. A 10.5 with 3.73s is very common, but the bolt pattern is different and the spring perches and shock mounts would have to be moved. Then you'd also have to change the front so that you're not running 2 different bolt patterns.
That being said, I love my 3.73s and will never go back to 4.10s.
So your options are (easiest first, IMO):
1. Get a complete 10.25 axle with 3.55s (direct swap)
2. Get a 3.73 ring and pinion from a SD 10.5 (or after market 10.25 gears) and swap them in.
3. Get SD front and rear 3.73 axles and move the spring perches and shock mounts.
If you're not really good with a wrench and willing to do lots of research on gear swaps, then number 2 gets moved to the bottom.
Old Aug 18, 2011 | 01:57 PM
Brown Falcon's Avatar
Brown Falcon
I have a 10.25 rear with 3.55's and a gear set for a Dana 60 3.54's from my parts truck that I'm cutting up...
You're a little ways away, but shoot me a PM if you are interested. I could pull the gears if that's all you want.
rekrap95
2004 - 2008 F150
Jul 18, 2017 11:41 PM
throwdown
35
Jan 5, 2011 02:46 PM
lawnspecialties
2004 - 2008 F150
Dec 28, 2006 05:25 PM
RattlerPSD
Nov 15, 2006 05:51 PM
LTDavis
1978 - 1996 Big Bronco
May 18, 2002 12:23 AM
