coolant filter?
Old Aug 17, 2011 | 08:53 AM
dothedew192's Avatar
dothedew192
coolant filter?
Hey guys, I have a question, I got my gauges installed in my truck about a month and a half ago. I've been closely monitoring my transmission temps because they are wayyyy higher then they should be for just daily driving. Some days its fine, and some days its at 220. Way to high for a half hour drive home..all highway and at 60. So, my question is is there a coolant filter in our cooling system? Its a 2002 f 350, I just had the fluid and filter changed about four months ago, probably 17,000 miles. A 6.0 tranny cooler is on my list of mods, probably sooner then later for obvious reasons. Thanks guys. And is there a parts package available for the 6.0 cooler swap in?? I'd love to order the cooler and a handcrafterd 6.0 cooler install package.
Old Aug 17, 2011 | 09:00 AM
guitarpicr's Avatar
guitarpicr
No coolant filter stock - Lots of us have added them.
Old Aug 17, 2011 | 10:23 AM
rufushusky's Avatar
rufushusky
Like mentioned above no coolant filter stock but I have a baldwin head and filter waiting to go in this weekend. 220 is a bit toasty, are you in traffic a lot in your ride home? How old is the fluid?
BTS, John Wood and a bunch of other vendors will sell you a 6.0 kit with the fitings you need. I got mine used off car-part.com for $100 and hit up a parker store for 30 bucks worth of fittings.
Old Aug 17, 2011 | 10:34 AM
SpringerPop's Avatar
SpringerPop
Your elevated trans temperatures may be due to a transmission lube oil "bypass valve" partially open all the time. It opens to immediately re-circulate the oil coming out of the trans (that goes up to the coolers) back to the input port that's coming back from the coolers.
It does this ONLY when the coolers get too much resistance to flow, which usually means crud built up in them. Of course, it could also be a pinched cooler line (it happens), or it could even be a faulty bypass valve opening at too low a pressure resistance.
There's a procedure for checking this which involves removing the rear cooler line and running the fluid to a collection pan. I believe that it's a quart in 15 seconds, minimum, and nothing coming out of the rear port. This test is done at engine idle.
If you perform this test and don't get the expected results, check back and we'll be more specific with continuing the diagnosis.
Pop
Old Aug 17, 2011 | 12:00 PM
dothedew192
Okay. Thank you very much. The bypass sounds like it may be applicable to this problem. Somedays its perfect and never goes above 150 to 180. Other days it rides 220 like nothing. And no, no heavy traffic. just let it go into overdrive and drive 60. No bad hills no nothing. 220 is very unacceptable for this thing doing 1800 rpms down the road. There's got to be a coolant flow issue or something among the likes. Tranny fluid is just a few months old. Filter and fluid changed almost 20000 miles ago.
Old Aug 17, 2011 | 01:04 PM
timmyboy76's Avatar
timmyboy76
Ths thread is a perfect example of why not to trust the factory gauge temp, but to install a/m gauges.
Old Aug 17, 2011 | 01:15 PM
clem1226's Avatar
clem1226
just to make sure.....
when you are saying coolant, are you referring to the transmission fluid? or are you following logic that your high transmission temp is due to an engine coolant/antifreeze issue?
Old Aug 17, 2011 | 02:43 PM
Pitcrw6's Avatar
Pitcrw6
x2 on this, I thought he was refering too a coolant/antifreeze filter
Old Aug 17, 2011 | 03:33 PM
Franko72's Avatar
Franko72
Molon Labe
It does this only when the coolers get too much resistance to flow, which usually means crud built up in them. Of course, it could also be a pinched cooler line (it happens), or it could even be a faulty bypass valve opening at too low a pressure resistance.
Pop
I completely agree, and while your doing the test, also test it at 2000 rpm. The flow should double from that at idle. Its a good way to check the pump in the trans.
I learned this from a Ford trans guru. A weak pump may still pass the test at idle.
Old Aug 17, 2011 | 05:08 PM
dothedew192
I apologise, I'm following the logic that my high transmission temperature is due to an antifreeze/coolant flow. I don't know a lot about the 4r100, but I am not correct in thinking the radiator also helps cool the transmission? I'll have to try the test out and see how much comes out. I won't be able to get it done till this weekend, I'll have to incorpporate it in with installing my hawk performance super duty brake pads I just received from riffraff.
Old Aug 17, 2011 | 07:16 PM
clem1226's Avatar
clem1226
you do have an OTW ( oil to water) as well as a OTA ( oil to air ) cooler on your truck. I think they started that on the 2001 model year? I highly doubt high coolant temps would be causing your high transmission temps, more than likely plugged transmission oil coolers, obstructed fins on your OTA cooler or crimped/plugged transmission lines.Another possibility is the bypass is sticking open on the transmission.
First thing to do would be to pull the return line off the transmission and see if you have oil circulating through the coolers.
Old Aug 17, 2011 | 09:27 PM
dothedew192
Ahh I see. I appreciate your time. That will be my next step. I thought the radiator helped cool the transmission. My mistake. If the fluid that comes out of the line isn't up to par, meaning fills the container a quart for every fifteen seconds. Take the coolers apart and clean them?
Old Aug 17, 2011 | 09:55 PM
Smokiesman's Avatar
Smokiesman
I don't think the coolers are designed to be taken apart and cleaned! You may be able to flush one out to clean but no take apart!!!
Smokie
Old Aug 17, 2011 | 10:03 PM
SpringerPop
My 2000 has the OTW, and I believe mine is not unique.
Pop
Old Aug 17, 2011 | 11:43 PM
timmyboy76's Avatar
timmyboy76
Originally Posted by dothedew192
I thought the radiator helped cool the transmission. My mistake. ?
Inadvertently, i think your correct, since the trans fluid runs in the radiator.
