I drive in the city most of the time so dont get any time on the open road had to run down to the capital today and its 50 miles so during the drive I was playing with my CTS and these are some numbers I came up with. Just wanted to make sure they looked ok to all of you as some of them I have no idea what they should be. Thanks in advance. Trucks runs great and there is 66,345 miles and yes I run a SCT tuner with Erics street tune on this trip. I have Matts tunes also. Ambient temp was around 75, was driving 65 mph
Intake Air Temp (IAT):80 degrees
ECT: 194 degrees
EOT: 199 degrees
Transmission Temp: 159 degrees
Fuel Pressure: 65.6
FICM voltage:48.5-49 I know you want this to be 48 but what can it go to
EGT: 575
ICP voltage:1.6
VGT%: 47.6 This one could go up fast or down fast with throttle change
TCC duty Cylce: 0.0 No clue what this is.
Turbo Boost: 7 psi
Manifold Abs Pressure: 21
Mass Air Flow: 140 another one that can really change with throttle.
Battery Voltage:13.6
Its cool that the CTS monitors FICM voltage, my only compalint about the DasDaq.
Also what did you have to use to get it to read fuel pressure. Looks like youve upgraded to the blue spring kit too.
Everything looks to be in line, good looking stats there, almost identical to mine.
Sarge
Thanks sarge, Yes I have done the blue spring. For the fuel pressure, I already had a guage so I used the existing hose. I had to buy a universal (Edges) sensor adapter and then the fuel sensor unit that goes in the daisy chain with the other (EGT) sensor.
It should change as you drive. I can program my DD to see what mine does but I wont be able to report back for a few days I am heading out of town to see my Aunt and Uncle in Pa.
