ARP stud install question?
Old Aug 16, 2011 | 07:05 PM
snorindad's Avatar
snorindad
The way I read the instructions the lube is only used on the nut side of the stud. And the studs should be only hand tight in the block and not torqued in the block. If someone could confirm this it would be appreciated. Also my kit only came with the 14m studs and not the 8mm so I assume you use the original 8mm bolts. Thanks
Old Aug 16, 2011 | 07:22 PM
AGE mechanic's Avatar
AGE mechanic
I dont know weather you have seen this or not. Check this out. Click on the pics to blow them up. I think you are correct about hand tight.
Ford 6.0L VT365 Power Stroke Engine Rebuild - Diesel Power Magazine
Old Aug 16, 2011 | 08:56 PM
429poweredf350's Avatar
429poweredf350
That is correct. The studs are threaded into the block hand tight. However, you must ensure that the holes have no oil in them prior to stud installation otherwise they don't seat properly. This will affect torque. Some use compressed air but I used Q-tips and they worked well. After the studs are installed, the lube is used on the nuts.
ToolmakerRob
Sep 12, 2017 09:08 AM
d-day
32
Mar 28, 2015 06:07 PM
fordboy300
Jan 7, 2012 12:47 AM
Bananarama
Modular V10 (6.8l)
44
Oct 10, 2010 06:02 PM
BEAVER
Aug 22, 2002 05:49 AM
