ipr numbers //what should my ipr numbers be hot at idle // 1200 rpm // and 1800 // and what is window on % i think maybe either my icp or ipr might be on the way out im seeing less than 400 at idle i got a stumble that seems to coinside with the pressure
thanks glen , i checked my manuals but cant find the range ?? yea im gonna hook my scanner up on the way home to.but i got a hpop gauge that i can read all the time for pressure . gonna look at % . and my lpop witch i also am suspecting might be getting weak.
if it stumbles at idle you might want to disconect the icp and see if it smooths out. if it does then you have a faulty icp.
driving home yesterday i checked my numbers at 1200 rpms and flat ground i was seeing around 700 and at 1800 rpms it was around 1500 on flat ground. these numbers were in 6th gear too.
Idling should be 500ish psi, but more importantly about 10% duty cycle. At WOT you want to see 2800+psi and hold that from 60-90mph and never go over 40% DC. If you drop to less than about 2200psi or higher than 40% DC - somethings up. Dirty IPR? IPR orings? Weak HPOP? Failing injectors? Bad inj. oring(s)?
