c6 vs e40d
Old Aug 15, 2011 | 12:07 PM
joe f350's Avatar
joe f350
c6 vs e40d
well i went to the doctor he in short my gear jaming day are coming to a end due to my knees breaking down so im not going to sell my truck
so that leaves me two choise the built proof c6 or the wireing night where that is the e40d
if i was going to do a c6 it i just get a c6 have it built to the hills and back so it last forever and just get a after market floor shifter but no od and sucky fuel millage
or the e40d the wiring nightmere with gears if i go that rought i get a stand alone controler and such but i know i would need a shifter and such i would probley try to fing a one out of a psd that all ready has the up grades the old redeaming thing the e4od has going for it is the od
Old Aug 15, 2011 | 12:19 PM
LSO1123's Avatar
LSO1123
I would gladly give up OD and some fuel economy to not have to worry about the TCU in my truck putting my tranny in limp mode cause some stupid fuse blew or some un important wire grounded out. A stand alone TCU such as the Optishift would be good but you're looking at another 600 bucks just for it.
Old Aug 15, 2011 | 03:13 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Joe, you being in CA, I actually wouldn't mind an E4OD to much, simple reason.
You have no winter, and hardly any rain. So very small chance of having electrical problems caused by those things.
Here where I am, I wouldn't dare on a E4OD.... especially not for long trips like I do. Better be safe than sorry.
Now your 2 tranny choices will depend on how deep your pockets are. It's gonna be a hellava lot cheaper building up a C6 than an E4OD.....
Then again, with the E4OD you gain OD and abit better mpg. But for the price difference, you'll have to keep your truck a LONG time to catch up on the difference. So it's up to you to figure that one out.
Old Aug 15, 2011 | 04:38 PM
LSO1123's Avatar
LSO1123
Not to hi jack the thread but how big a deal would it be to change an e4od out to a c6?
Old Aug 15, 2011 | 05:53 PM
swooshcmk's Avatar
swooshcmk
E4OD > C6. C6 is shorter so driveshafts change lengths. Trans x-member moves forward a few inches. Wiring changes from MPLS to the reverse and park/neutral safety switch is fairly minor. TPS on the IP changes to the vacuum unit used on the C6 for the tranny vacuum modulator. Shift linkage on E4OD was cable vs the multi-pivot linkage of the C6. That pretty well sums it up I think.
Old Aug 15, 2011 | 05:54 PM
swooshcmk's Avatar
swooshcmk
Joe, E4OD has a lower geared 1st and 2nd gear than a C6. Might be handy if you're going to tow or offroad it ever. Not that my C6 has ever hard a hard time getting going with it's higher 1st/2nd gear heh. But I can't break my rears lose with my LSD. Gotta put some air in the rear brake line I guess lol
Old Aug 15, 2011 | 06:25 PM
David85's Avatar
David85
Just to add, the shift linkage changed over to cable for the 1992 model year. 1991 and older trucks equipped with E4ODs had a shift linkage almost identical to the C6. The actual shift rod that reaches to the lever on the side of the transmission is longer for the E4OD.
Old Aug 15, 2011 | 06:43 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
whats a C6 lol?
my god you guys.i can't believe this is even a debate in your minds.
Old Aug 15, 2011 | 06:48 PM
swooshcmk's Avatar
swooshcmk
I'm E4OD all the way. Just gotta find time to put mine in! My breakdown goes like this. Do you need your truck to survive an EMP explosion? If yes, C6. If you vote that's not likely needed, go E4OD. Middle of the road being rewire your E4OD control computer to be shielded from EMP's.
Old Aug 15, 2011 | 06:53 PM
David85's Avatar
David85
The E4OD will survive an EMP. Even without the computer, you can still limp in 2nd, 4th or reverse. More than enough to outrun (or run over) any zombies.
As bad as the reputation may have been in the early years, you can make them as bullet proof as you need. Either pay through your nose to have one made by an outfit like BTS, pay a mid range for a resonable build in the form of a ford dealer transmission (nation wide warranty) or do your homework and build it yourself.
Old Aug 15, 2011 | 07:07 PM
ford390gashog's Avatar
ford390gashog
I like C6's but hands down I vote for an E4OD with an aftermarket controller and be done with it!
My left knee is at 35% and my right knee is at 40%! It is painful some days!
Old Aug 15, 2011 | 08:08 PM
LSO1123's Avatar
LSO1123
I have no problem with the e4od itself, its the computer I hate. I need to just fork over the dough for an after market controller and shut up about it! Lol
Old Aug 15, 2011 | 08:50 PM
IDIDieselJohn
I'm C6 all the way
Old Aug 16, 2011 | 11:05 AM
joe f350's Avatar
joe f350
cents me and the gf may be moveing to the coast in the next few mounths i think im gona swap in a c6 with a after market floor shifter going with the k.i.s.s method
Old Aug 16, 2011 | 11:15 AM
IDIDieselJohn
Now your talking!
