DTC code
Old Aug 14, 2011 | 07:59 PM
bielenbergr's Avatar
bielenbergr
DTC code
I have a 2004 f350 dually with the 6.0 and i just got a dtc P0402. Courious on what this code is any help would be great
Old Aug 14, 2011 | 08:05 PM
BLADE35's Avatar
BLADE35
P0402 Exhaust Gas Recirculation "A" Flow Excessive Detected G* g D* M* N
try cleaning your egr valve
Old Aug 14, 2011 | 08:08 PM
bielenbergr
What would cause this and how do i fix it
Old Aug 14, 2011 | 08:26 PM
BLADE35's Avatar
BLADE35
your egr valve needs to be cleaned or replaced sounds like its getting stuck open
sorrey that prints small when I cut and paste stuff
heres one that reads better
P0402 C* Exhaust Gas Recirculation Flow Excessive Detected EGR Valve Position does not match desired, limits based on
engine speed / load.
EGR Valve stuck or sticking - EGR Valve Position Sensor Bias - EP
Old Aug 14, 2011 | 08:30 PM
bielenbergr
where is it located and what do i do to fix it. Does it need to be done right away
Old Aug 15, 2011 | 12:59 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
It should be done soon....you don't want to blow your head gaskets.
Old Aug 15, 2011 | 01:04 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Clean it soon.
DTS Articles - EGR Servicing
Info:
DTS Articles - EGR Marbles
Old Aug 15, 2011 | 01:41 PM
JESTERxHEAD's Avatar
JESTERxHEAD
How does a sticking EGR valve cause a blown HG?
Old Aug 15, 2011 | 01:57 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Superheats the coolant..... superheated coolant cannot expand under the heads...the 6.0 has torque to yield head bolts. Pressure lifts the heads and the gaskets are compromised.
Old Aug 15, 2011 | 02:40 PM
JESTERxHEAD
How does it "superheat" the coolant?
Is there something I am missing.....
Old Aug 15, 2011 | 06:21 PM
cheezit's Avatar
cheezit
and just what kind of air filter do you have?
been donw the p0402 road more then once
Old Aug 16, 2011 | 11:02 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Sorry - was confusing the EGR cooler with the engine oil cooler... however when one fails, the other isn't far behind. If the ENGINE oil cooler plugs, then my statement holds. Again I apologize for reading something that wasn't really there.
Old Aug 20, 2011 | 01:21 PM
bielenbergr
Thanks everyone
propellerhead
1983 - 2012 Ranger & B-Series
Jun 14, 2013 08:14 PM
MikeB 88
Aug 4, 2010 06:13 PM
Bigches
Feb 5, 2008 12:21 AM
w8jumper
Jul 2, 2007 10:35 PM
NMpatronis
Feb 19, 2005 10:37 PM
