EGR Valve and position sensor
Old Feb 14, 2005 | 12:02 AM
NMpatronis's Avatar
NMpatronis
Hello all. I the FNG so I apologize for this possiably stupid question. I have a 91 F150 with a 302. The computer was throughing a code so I had it checked out. My EGR valve and EGR position sensor is not working. First: are these hard to replace?, two: where are they located? three: Where can I find some cheap replacements? Four: Is the EGR Valve ad Position sensor interchangeable with one from a Mustang 5.0?
Thanks for any info you might have,
Nick
Old Feb 14, 2005 | 09:49 AM
brown 4x4's Avatar
brown 4x4
What code are you getting? The valve and sensor may not actually be bad. I've fixed a couple with code 332 - "Insufficient EGR flow" by taking the EGR valve off and cleaning it.
Old Feb 14, 2005 | 10:49 AM
NMpatronis's Avatar
NMpatronis
It's actually my GF's car. She took it to the ford Dealership and they told her EGR Valve problem. So will look into it and get back to you.
Thanks
Old Feb 18, 2005 | 01:17 AM
NMpatronis's Avatar
NMpatronis
I am getting code 34 which I beleve is EGR stuck open. Aslo now the truck starts and shuts off, it wont stay running??????
Old Feb 19, 2005 | 09:29 PM
95f150's Avatar
95f150
try getting your fingers under the diaphram on the egr valve and manually stroke it, thats what i did with the old ladys car. its probably best to take it off though and clean it.
Old Feb 19, 2005 | 10:37 PM
MemOrex's Avatar
MemOrex
Remove the EVP Sensor (above EGR valve...3 bolts). Once removed, push down on the EGR valve from the inside to get it unstuck.
Removing it can be a pain. I should know, I've yet to remove mine....
