Just a question for whoever reads this. I was planning on putting in recessed, directional lights in the front and back, kind of like map reading lights. I can't seem to find any. Ideas on what I can use?
Interior/dome light from a 96? is sort of dome light in the middle and mini spot light ish on the ends???? if I remember right? Hit the JY and let up know what you find.
That was one of the ones i was thinking of. LMC truck doesnt have any, so i will make a run to a jy sometime
You guys did a great job. I like how you painted it to match your interior. I showed my wife & told her I am going to do one also with some toggle switches for future components/lights. I think I will make mine a small strip maybe 8 inches by 4 inches and then put headliner up with a cut-out maybe 5 1/2 inches by 3 1/2 inches. Thanks for sharing your guys projects and ideas.
If you have a Camping World in your area(or any other RV store), you might find some lights designed for RVs that would do the trick.
No problem
One of the reason im making mine full length is i don't have a headliner, and the sheet of material that i do have is too small. I made mine 8 inches wide, so i will have 2 seperate headliner pieces each 24 inches wide and 50 inches long. I could've bought a bigger sheet, but this sounded like more fun.
Looks great....I want to see some daylights pics though.
I get some tomorrow.
It actually doesnt match perfectly. I was to cheap to get actual auto paint so I got 2 colors of Rustoleum spraypaint and layered them together. One was metallic so it is fairly close to the right color but you can definitely tell during the day.
