oil pressure sending unit
Old Aug 13, 2011 | 10:42 PM
ericdes's Avatar
ericdes
Hello
2001 ranger 2.3 liter 5 speed 167k miles.
I see the oil gauge needle occasionally flicker an 1/8 inch or so. I heard this is a dummy gauge and it either has pressure or it does not. I was going to swap out unit.
I found it next to the oil filter under truck.
Any suggestions /tips in swapping this sending unit out?
Thanks
Old Aug 13, 2011 | 11:01 PM
Rackster's Avatar
Rackster
Dummy Gauge
Eric,
Yes, I believe you are correct: gauge is meant to show if there is pressure or if there isn't. I saw a link at the Ranger Station to a guy who builds 2.3L engines and has a trick to convert the dummy gauge into a functional gauge by soldering in a resistor or something. It's been a while, so I don't recall the details now.
Flicker could mean a bad gauge, bad connection, or it dies out for a second because the pressure drops. You may need to do some more trouble shooting to diagnose the issue properly.
Good luck!
Kevin
Old Aug 13, 2011 | 11:23 PM
michigan66's Avatar
michigan66
Look in the "Technical Information" section at the beginning of the index page and look for "Oil Pressure Gauge Conversion."
Old Aug 14, 2011 | 05:58 AM
greenpus's Avatar
greenpus
These trucks have crappy oil sending unit. Replace it and your flicker will go away.
But as a safety precaution, you should check your oil pressure just to make sure.
I installed a 3 pod A-pillar unit and added a rpm, oil pressure and volt meter gauge. Love it.
goodbread
51
Jan 13, 2015 10:17 PM
slc10844
Aug 7, 2012 02:02 PM
advocate
1997 - 2003 F150
Nov 25, 2009 09:05 AM
imfinethanx
Modular V8 (4.6L, 5.4L)
Jan 18, 2008 12:02 AM
dumyfou
15
Jul 6, 2007 07:29 PM
